K606's avatar
K606
1 year ago
Linux mSGDMA Driver Agilex 5
I am trying to use stream-to-memory DMA to move data.
This is the design, showing the important Quartus connections: 
Which corresponds to this address config:
# address map
write_sdram       = 0x00000000
read              = NULL (has no meaning in streaming to MM mode)
msgdma_csr        = 0x22000040
msgdma_descriptor = 0x22000060
# msgdma offsets
msgdma_csr_control          = 0x4 + 0x22000040 = 0x22000044
msgdma_descriptor_write_low = 0x4 + 0x22000060 = 0x22000064
msgdma_descriptor_length    = 0x8 + 0x22000060 = 0x22000068
msgdma_descriptor_control   = 0xc + 0x22000060 = 0x2200006c
The oscillator IP generates a group of known numbers, so the readbacks change each time - but are predictable and so the hardware is verifiable.
In U-Boot; I have verified that this design. This script asks the DMA to make two transfers, and reads back the results each time.
SOCFPGA_AGILEX5 # mw 0x22000044 0x1 # Stop Dispatcher
SOCFPGA_AGILEX5 # mw 0x22000044 0x20 # Stop descriptors
SOCFPGA_AGILEX5 # mw 0x22000044 0x2 # Reset Dispatcher
SOCFPGA_AGILEX5 # mw 0x22000064 0x00000000 # Write address
SOCFPGA_AGILEX5 # mw 0x22000068 0x8 # Write length in bytes
SOCFPGA_AGILEX5 # md 0x22000040 1 # Check status
22000040: 00000002                             ....
SOCFPGA_AGILEX5 # mw 0x2200006c 0x02000000 # Wait for response
SOCFPGA_AGILEX5 # sleep 1
SOCFPGA_AGILEX5 # mw 0x2200006c 0x82000000 # execute
SOCFPGA_AGILEX5 # md 0x00000000 1 # read
00000000: 00000000                             ....
SOCFPGA_AGILEX5 # mw 0x22000044 0x2 # reset
00000000: 67676767                             ....
When trying to do the same in linux using 'devmem2', I found that the readbacks did not change, so I decided to look for some examples.
I found this stream-to-mapped mSGDMA driver built for the Cyclone V, and so re-purposed it.
The driver example above both reads and writes to the device using the ‘dd’ utility in linux, but I am for now only interested in the read command. To do so I needed some information...
Based on the .qsys design file output of my project, the mSGDMA block generates this interrupt:
<altera:connection altera:kind="interrupt" altera:version="24.3" altera:start="subsys_hps.f2h_irq0_in" altera:end="msgdma_0.csr_irq">
  <altera:connection_parameter altera:parameter_name="irqNumber" altera:parameter_value="2">
  </altera:connection_parameter>
</altera:connection>
And according to the interrupt docs, the above csr interrupt value=2 maps to the GIC interrupt 51, which is 19 when referenced from the linux device tree.
With this information, I have defined the following mSGDMA element in the .dts:
msgdma_test: msgdma_test@22000000 {
compatible = "msgdma_test";
    	reg = <0x0 0x22000000 0x0 0x100>;
	interrupt-parent = <&intc>;
	interrupts = <0 19 4>;
Which only differs from the original in that it has a different interrupt number, and different base address - also accounting for the lwhps2fpga offset, due to it being the Agilex5 and not the Cyclone.
The driver code from the REDS blog post has also been edited in the following way:
  1. I need to change a deprecated function in the main driver code: devm_ioremap_nocache to demv_ioremap.
  2. I want to see the data which has been moved - to do so have added an info print to the msgdma_read method: printk(KERN_INFO "MSGDMA: Read buffer content: %.*s\n", (int)read_ret, (char*)data->dma_buf_rd);
  3. There is only 1 interrupt, so we set data->msgdma1_irq = platform_get_irq(pdev, 0);
Since there is no ability coded to fabric to perform msgdma_write - we can also remove memory allocations, remaps and references to msgdma0 and other write related objects.
I think the following shows that the DMA is firing interrupts, and so I am confident that I have connected the correct interrupt:
cat /proc/interrupts | grep msgdma
50:          2          0          0          0     GICv3  51 Level     msgdma1
However, when looking at the kernel outputs after requesting reads via dd:
$ dd if=/dev/msgdma_test of=/dev/null bs=8 count=1
$ dmesg | tail
[ ... ] MSGDMA: Read buffer (hex): 00 00 00 00 00 00 00 00
The driver code in question is included in msgdma.c and header_msgdma.c, attached to the post (This forum does not seem to like .h files...)
I was hoping someone might have an idea of where I went wrong!
Any helpers are much appreciated!
Thanks for your time,
K
  • Hi,
    if you have a GHRD for your current board you can easily adapt the HW design (created for a supported board via e.g. build_hw_f2h_bridge.sh). The external periphery required on the demo designs is minimal (HPS-EMIF, HPS clock and UART).
  • Hi wangduoyu,
    I see you started a new thread with this question. Let's work on it there.
    Sue
  • wangduoyu's avatar
    wangduoyu
    Hello, I am also currently working on MSGDMA development. I have successfully established access to the MSGDMA CSR and Descriptor registers via the LWH2F bridge using devmem2. My setup is configured in Streaming-to-Memory-Mapped (ST-to-MM) mode, similar to yours.
    I have two specific questions regarding the implementation:
    1、Is configuring the standard Linux kernel driver a mandatory prerequisite for the MSGDMA to function correctly, or can it operate independently?
    2、I noticed that you are writing to the PS-side memory via the FPGA-to-HPS bridge. However, my design utilizes the F2SDRAM (FPGA-to-SDRAM) interface path, as indicated by the numbered sequence in the attached diagram. Could you please confirm if this architectural approach is feasible?
  • Jeet14's avatar
    Jeet14
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
  • Jeet14's avatar
    Jeet14
    Hi K606,
    Please let us know if you have any question on this.
    Tiwari
  • StefanG_Altera's avatar
    StefanG_Altera
    the agilex5-demo-hps2fpga-interfaces repo supports different boards including our Agilex 5 Premium Development kit (that features the device you mention). You can build the HW for one specific example (for one particular board) using the individual build scripts. First you have to initialize the HW build script for a particular board and build a specific HW project (e.g. build_hw_f2h_bridge.sh) as described in https://github.com/altera-fpga/agilex5-demo-hps2fpga-interfaces/blob/main/documentation/17_building_project.md
    In contrast to the board specific GHRD the demo designs are tailored for each test-case.
    • K606's avatar
      K606
      Hi Stefan,
      Ah yes the part is there!
      Sorry for the typo, I did mean that my board is not listed.
      So if the part number is matching, then these examples should build fine for the board I am using?
      Thanks again,
      K
        StefanG_Altera
    StefanG_Altera
    You may be interested in checking the "HPS-FPGA Interface Demos" for Agilex 5.
    The introductory documentation explains the demos repository concept and what examples are included.
    One example that may be of interest is the "F2H-Bridge": it uses a msgdma core to stream data across the F2H-Bridge from an internal FPGA RAM to EMIF buffer and vice-versa. Its a different approach than using a driver, the descriptors are pushed into the msgdma and the DMA duration time is computed in the app.
    The demos are run under u-boot (using u-boot API) but some have been ported to Linux environment.
    The code of the "F2H-Bridge" Linux Application: https://github.com/altera-fpga/agilex5-demo-hps2fpga-interfaces/blob/main/common_sw/linux_apps/f2h_bridge.c
    • K606's avatar
      K606
      Hi Stefan - thanks for getting back to me!
      Ok great; I will look into this.
      I have a question though - I have been using a GHRD which is based on an Agilex which is not listed in any of these example.
      It is the A5ED065BB32AE4SR0.
      Would it be complex to pop that into the designs in question and have it run OOB?
      Many thanks,
      K
