Interrup numbers of Arria 10 EDAC
Hi Fawaz,
Thank you for your support and time. I did also some additional tests on my side and found a solution:
It seams, that the ECC/EDAC driver doesn't like the kernels Power Management. In short, additional to the documentation, i disabled also the following Power management options in the kernel configuration (both are enabled by default):
Power management options -> [ ] Suspend to RAM and standby Power management options -> [ ] Device power management core functionality
And now the kernel boots as excepted and the ECC driver is loaded correctly.
The reason why I enabled the EDAC is another issue on the EMAC or on the Ethernet connection. Unfortunately, the EDAC didn't report any error and I still observe the issue. I started a new thread here: https://community.intel.com/t5/Intel-SoC-FPGA-Embedded/High-Latency-Ethernet-on-Arria-10-SoC-device-using-HPS-EMAC-and/m-p/1704797#M3220
@FawazJ_Altera maybe you have any information about this topic?
First for completeness, the boot log in the failure case is here (maybe it helps some one else):
Starting kernel ... Deasserting all peripheral resets [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 6.6.97-00006-g68629dbe4aeb-dirty (silvan@heldsksm1) (arm-linux-gnueabi-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #34 SMP Tue Jul 22 10:27:04 CEST 2025 [ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: ABC [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000000000000-0x000000002fffffff] [ 0.000000] HighMem [mem 0x0000000030000000-0x000000003fffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000000000-0x000000003fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003fffffff] [ 0.000000] percpu: Embedded 15 pages/cpu s31764 r8192 d21484 u61440 [ 0.000000] Kernel command line: root=/dev/mmcblk0p5 ro rootwait console=ttyS0,115200 rootfs=ext4 [ 0.000000] Unknown kernel command line parameters "rootfs=ext4", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260608 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] Memory: 1025036K/1048576K available (9216K kernel code, 849K rwdata, 2172K rodata, 1024K init, 159K bss, 23540K reserved, 0K cma-reserved, 262144K highmem) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] ftrace: allocating 33000 entries in 97 pages [ 0.000000] ftrace: allocated 97 pages with 3 groups [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] L2C-310 erratum 769419 enabled [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9 [ 0.000000] L2C-310: enabling full line of zeros but not enabled in Cortex-A9 [ 0.000000] L2C-310 ID prefetch enabled, offset 1 lines [ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled [ 0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB [ 0.000000] L2C-310: CACHE_ID 0x410030c9, AUX_CTRL 0x76560001 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns [ 0.000001] sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 21474836475ns [ 0.000015] Switching to timer-based delay loop, resolution 10ns [ 0.000453] Console: colour dummy device 80x30 [ 0.000501] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=1000000) [ 0.000516] CPU: Testing write buffer coherency: ok [ 0.000556] CPU0: Spectre v2: using BPIALL workaround [ 0.000563] pid_max: default: 32768 minimum: 301 [ 0.000716] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.000730] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.001563] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.002631] RCU Tasks Rude: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2. [ 0.002781] Setting up static identity map for 0x100000 - 0x100060 [ 0.002975] rcu: Hierarchical SRCU implementation. [ 0.002982] rcu: Max phase no-delay instances is 1000. [ 0.003561] smp: Bringing up secondary CPUs ... [ 0.004397] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.004417] CPU1: Spectre v2: using BPIALL workaround [ 0.004573] smp: Brought up 1 node, 2 CPUs [ 0.004586] SMP: Total of 2 processors activated (400.00 BogoMIPS). [ 0.004595] CPU: All CPU(s) started in SVC mode. [ 0.005541] devtmpfs: initialized [ 0.010215] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.010447] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.010469] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.011733] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.012589] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.013632] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 0.013645] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.029627] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible. [ 0.035917] SCSI subsystem initialized [ 0.036102] usbcore: registered new interface driver usbfs [ 0.036150] usbcore: registered new interface driver hub [ 0.036193] usbcore: registered new device driver usb [ 0.036541] pps_core: LinuxPPS API ver. 1 registered [ 0.036549] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]> [ 0.036575] PTP clock support registered [ 0.036592] EDAC MC: Ver: 3.0.0 [ 0.037164] FPGA manager framework [ 0.038055] vgaarb: loaded [ 0.039190] clocksource: Switched to clocksource timer1 [ 0.052140] NET: Registered PF_INET protocol family [ 0.052411] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.054264] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear) [ 0.054299] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.054314] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 0.054390] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear) [ 0.054625] TCP: Hash tables configured (established 8192 bind 8192) [ 0.054770] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.054837] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.055053] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.059380] RPC: Registered named UNIX socket transport module. [ 0.059392] RPC: Registered udp transport module. [ 0.059397] RPC: Registered tcp transport module. [ 0.059401] RPC: Registered tcp-with-tls transport module. [ 0.059405] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.059422] PCI: CLS 0 bytes, default 64 [ 0.060611] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available [ 0.062115] workingset: timestamp_bits=30 max_order=18 bucket_order=0 [ 0.062787] NFS: Registering the id_resolver key type [ 0.062866] Key type id_resolver registered [ 0.062871] Key type id_legacy registered [ 0.063236] ntfs: driver 2.1.32 [Flags: R/W]. [ 0.063265] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc. [ 0.063755] bounce: pool size: 64 pages [ 0.063791] io scheduler mq-deadline registered [ 0.063798] io scheduler kyber registered [ 0.063824] io scheduler bfq registered [ 0.069021] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 0.071605] ffc02000.serial: ttyS1 at MMIO 0xffc02000 (irq = 30, base_baud = 6250000) is a 16550A [ 0.072729] ffc02100.serial: ttyS0 at MMIO 0xffc02100 (irq = 31, base_baud = 6250000) is a 16550A [ 0.072780] printk: console [ttyS0] enabled [ 0.738034] ff251000.serial: ttyAL0 at MMIO 0xff251000 (irq = 32, base_baud = 12500000) is a Altera UART [ 0.750168] brd: module loaded [ 0.758992] loop: module loaded [ 0.764253] spi_altera ff250000.spi: regoff 0, irq 33 [ 0.770775] spi_altera ff250020.spi: regoff 0, irq 34 [ 0.776592] spi_altera ff250040.spi: regoff 0, irq 35 [ 0.784886] CAN device driver interface [ 0.789110] socfpga-dwmac ff802000.ethernet: IRQ eth_wake_irq not found [ 0.798917] socfpga-dwmac ff802000.ethernet: IRQ eth_lpi not found [ 0.805159] socfpga-dwmac ff802000.ethernet: Deprecated MDIO bus assumption used [ 0.813139] socfpga-dwmac ff802000.ethernet: User ID: 0x10, Synopsys ID: 0x37 [ 0.823158] socfpga-dwmac ff802000.ethernet: DWMAC1000 [ 0.828369] socfpga-dwmac ff802000.ethernet: DMA HW capability register supported [ 0.835849] socfpga-dwmac ff802000.ethernet: RX Checksum Offload Engine supported [ 0.843322] socfpga-dwmac ff802000.ethernet: COE Type 2 [ 0.848535] socfpga-dwmac ff802000.ethernet: TX Checksum insertion supported [ 0.855562] socfpga-dwmac ff802000.ethernet: Enhanced/Alternate descriptors [ 0.862503] socfpga-dwmac ff802000.ethernet: Enabled extended descriptors [ 0.869270] socfpga-dwmac ff802000.ethernet: Ring mode enabled [ 0.884449] Micrel KSZ9031 Gigabit PHY stmmac-0:07: attached PHY driver (mii_bus:phy_addr=stmmac-0:07, irq=POLL) [ 0.898358] loaded device eth0, tx_queue_len 1000, features: 71468255824179 [ 0.899428] usbcore: registered new interface driver usb-storage [ 0.912595] i2c_dev: i2c /dev entries driver [ 0.920654] EDAC DEVICE0: Giving out device to module l2-ecc controller Altera ECC Manager: DEV l2-ecc (INTERRUPT)
