How to program FPGA in Arria 10 HPS?
- 2 years ago
Hi sunyeong,
You can refer to this document on building the bootloader method using Arria10:
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10
Arria 10 FPGA configuration is done in two steps:
Configuration of periphery(periph.rbf): this allows HPS DDRAM to be brought up, and must do be done in SPL
Configuration of fabric(core.rbf): it configures the actual FPGA core fabric, and can be done from SPL or U-Boot
Aik Eu
Hi sunyeong,
Aik Eu
Thank you for your comments.
The document you provided was very helpful.
But I have below several questions.
- It seems that the feature you mentioned is similar to Early IO Release feature.
Is this right? - It seems that there is some customizing point in SPL for early IO release feature.
In fit_spl_fpga.its, rbf file is described as "fpga-periph-1", "fpga-core-1" name.
But in SPL code, rbf file is loaded using specific names("fpga-core", "fpga-periph").
(first_loading_rbf_to_buffer(), drivers/fpga/socfpga_arria10.c)
I want to modify some names(fpga-periph-1, fpga-core-1) in fit_spl_fpga.its.
(fpga-periph-1 -> fpga-periph, fpga-core-1 -> fpga-core)
Is this the correct way for this feature? - some functions releated with fpga is not called.
It seems that spl_fit_load_fpga()(in spl_fit.c) function is not called.
Is this code not used in Arria 10?
Thank you.
Jung.
