HPark14
4 months agoF2SDRAM fails to synthesize with custom logic
Hello guys, We are using Agilex5 SOC F2SDRAM bridge. I am trying to connect custom logic to the F2SDRAM, but it absolutely refuses to synthesize unless I export the signals directly to the top-lev...
- 4 months ago
Hello guys,
I've resolved this issue. Thank you for your support.
I created a r_out register and exported it to the top-level output
after that Quartus compilation succeeded.
HPark14
4 months agoThank you for your reply I am building the agilex5-demo designs. I will check the f2sdram reference design.
Thanks~
Archer_Altera
4 months agoHi HPark14,
I suggest you to add one AXI bridge component between f2sdram interface of HPS and AXI master interface of your own module. Then this error will disappear. You may see other error but they may be solved easier.
Hope this is helpful.
Archer_Altera
