HPark14
4 months agoF2SDRAM fails to synthesize with custom logic
Hello guys, We are using Agilex5 SOC F2SDRAM bridge. I am trying to connect custom logic to the F2SDRAM, but it absolutely refuses to synthesize unless I export the signals directly to the top-lev...
- 4 months ago
Hello guys,
I've resolved this issue. Thank you for your support.
I created a r_out register and exported it to the top-level output
after that Quartus compilation succeeded.
kbrunham_altera
4 months agoHi Hudson,
I believe the issue is your rdata_r is not preserved and thus gets optimized away. You may be able to see that in the synthesis report.
To preserve registers you can use the syn_preserve attribute on your declaration of the register.
