F2SDRAM fails to synthesize with custom logic
- 4 months ago
Hello guys,
I've resolved this issue. Thank you for your support.
I created a r_out register and exported it to the top-level output
after that Quartus compilation succeeded.
Hi Hudon,
The error Quartus is reporting is illegal connectivity of the RDATA interface. The device legality requires that this interface be connected to registers. I suspect that in your axi_master_tester component you are leaving rdata unconnected or tied off to a constant. What is needed is to create preserved registers that you connect to this interface.
You can see a similar example in https://github.com/altera-fpga/agilex5-demo-hps2fpga-interfaces/blob/main/custom_ip/h2f_termination_hw.tcl#L208
"If more detailed messages were provided, I would debug it myself, but it only gives one-word answers like a parrot."
