DMA plan on the Agilex5
I am looking to build a very basic mSGDMA example design and test it on the Agilex-V.
The plan is to program software on the SoC (running linux), which will tell a DMA (memory-mapped to memory-mapped) to move data from one on-chip-memory block to another.
I have two ideas for a design, sketched out below:
My hope is that with design B, I might be able to:
1: use /dev/mem to read from ocm_write (record initial state)
2: use /dev/mem to write to ocm_read (write a simple pattern)
3: initiate a transfer from ocm_read to ocm_write using the DMA
4: use /dev/mem to read from ocm_write (check to see if the state has changed)
So far, I have compiled both designs A and B using only Intel IP. I have not included any custom verilog based drivers. Nothing is tested yet on hardware.
I am making this post to hopefully get some more opinions/sanity checks that this is not barking up the wrong tree - so in that respect, does this plan seem reasonable?
Many thanks!
K
Q1: "Would this [UART firmware programming] be achievable via device tree edits?"
Not directly. The device tree (DT) describes the hardware for Linux — it’s used by the kernel to understand available peripherals like UART, memory regions, DMA, etc. It does not affect how bootloaders or firmware tools work.
In terms of UART firmware burning, DT changes won’t enable UART-based firmware flashing unless:
You're writing a custom bootloader or application that reads firmware data via UART and writes it to flash.
You use DT to mark certain memory regions as non-cached (helpful if the loader runs under Linux).
Q2: "If I understand correctly, you are saying that /dev/mem does not flush/handle cache in any way?"
Correct.
/dev/mem provides raw access to physical memory — but:It bypasses Linux’s cache coherency management.
Reads/writes using /dev/mem do not flush or invalidate the CPU cache.
This means if DMA wrote data to memory, but cache holds stale data, a read from /dev/mem may show incorrect results unless:
You manually flush/invalidate the cache in user space (not trivial).
Or you map the memory as non-cacheable (preferred approach).
Recommendations for DMA Testing with Cache Coherency:
Use dma-coherent memory:
In DT: use dma-coherent; or map memory via dma_alloc_coherent() if in kernel driver.
Mark OCM region as non-cacheable via DT:
E.g., using no-map; and specifying memory-region entries.
Avoid caching in /dev/mem mappings:
Use mmap() with O_SYNC and MAP_SHARED to minimize caching.
Flush/invalidate cache manually:
Possible from kernel space.
User-space solutions are hacky and not guaranteed.
- RolandoS_Altera
Hello
This is Rolando and I will try to help you. The example that you want to develop, you want to move a set of data from one OCM to another OCM. Right now I just remember an example that was implemented for Agilex 7 in which a set of data is being moved from one memory location of main memory (SDRAM) to another memory location using the mSGDMA IP. This example is located at:
Please give me some time to find another example that could be closer to what you want to do.
Rolando
- JitLoonL_Altera
Yes, your plan is quite reasonable and aligns with a common approach for validating simple DMA flows using Intel’s Modular SGDMA (mSGDMA) IP on SoC platforms like Agilex-V. You’re approaching this the right way by minimizing custom logic and using /dev/mem to manipulate and validate memory contents.
Here are some thoughts and sanity checks:- mSGDMA Setup: Ensure that your mSGDMA is configured in memory-mapped to memory-mapped mode, with Avalon-MM ports connected to both OCM blocks properly. Avoid scatter-gather mode for this test.
- Memory Region Mapping: Make sure the OCM blocks are mapped to accessible physical addresses and not optimized away or restricted by MMU settings in Linux.
- Be aware of potential issues with cache when using /dev/mem on a Linux system.
- Use dma-coherent memory or flush/invalidate the cache before/after DMA if required (or mark the region as non-cacheable via device tree or MMU settings if needed).
- You'll need to write to the mSGDMA’s control/status registers through /dev/mem too, to provide the transfer descriptor: source addr, dest addr, length, start, etc.
- This part is often trickier than expected. Ensure you’ve got the right base address and offsets from the Platform Designer output.
- OCM blocks must be large enough and have enough address range to hold your test patterns.
- Align your transfers to word boundaries expected by the DMA.
Suggestions:
- Add small test patterns like 0xAA55AA55 or a known incrementing pattern to easily spot transfer errors.
- Start with a small transfer size (e.g., 16–64 bytes) and scale up once the mechanism is confirmed.
- Use hexdump or a simple userspace C program for /dev/mem access to make reads/writes easier and more repeatable.
Points of Caution:
- mSGDMA might not complete the transfer if any part of source/destination addresses is incorrect or misaligned.
- /dev/mem might be blocked or restricted depending on your kernel config — check permissions or run as root.
- Some Agilex SoC configurations need proper HPS handoff from the bootloader to allow memory-mapped access cleanly.
- RolandoS_Altera
Hello
I couldn't find any example design exactly as the one you want to create, but I was able to create a design which is based on our Agilex 5 GHRD. This design is very similar to the CONFIG B that you have. The only differences is that I connect the OCRs blocks to the HPS2FPGA bridge instead of the LWHPS2FPGA bridges as this is how we do it in our GHRD. Also we keep the interrupt in the MSGDMA disconnected.
I am still trying to verify the functionality of the design from Linux created also from the GSRD of the Agilex 5 device (Premium Dev Kit).
To verify this I am using the devmem2 command to write to the OCRs and also to the registers in the MSGDMA. So far I can confirm the writing/reading to/from the OCRs works fine. The configuration that I am using the MSGDMA component is the same than the one provided in the Bridges examples that I shared earlier.
- K404
Hi Ronaldo,
Thanks for your input!
I look forward to hearing if you can verify your design.
Many thanks!
- K404
Hi JitLoon,
Thanks for your reply - very useful! I have a few questions, I hope it's ok:
On point 2: would this be achievable via device Tree edits?
On point 3: if I understand correctly you are saying that dev/mem does not flush/handle cache in any way?
Many thanks,
K(By the way, sorry, I had to make another account as the phone with my old my authenticator app is having issue
- JitLoonL_Altera
Correct.
- K606
Contributor
Thanks JitLoon,
This helped a lot.
K
- RolandoS_Altera
I was able to test this example in Linux and it also works, but I found out that the Descriptor registers in the MSGDMA controller are write only registers and I can't write to them using the regular devmem2 command because this performs a read/write/read-back operation in each write so I had to modify the application to perform only a write whenever I wanted to do a write. I am attaching the application that I used to validate the design.
- K606
Contributor
Hi Rolando,
Wow great! I wish I could also add your post to 'Accepted Solution'. Next time. Thanks for your time.
- BoonBengT_Altera
Moderator
Hi @K606,
As your doubts has been clarified and with no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread.
Please login to ‘ https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
