cyclone v ddr3 hard ip with multiport
Hi Everyone,
Im using cyclone V Soc evb board and Im trying to build example design for the ddr3 hard ip.
we are using quartus version 18.1.
memory clk: 400Mhz.
ddr interface data width:32bits
multiport: using only one port of 128bits.
pll ref clk = 100Mhz.
my question is about the clocks used for the avalon bus.
when I'm synthesizing the example design I can see that it catches 2 pll's:
1)pll for the hard ip that generates the 400Mhz, halfclk-200Mhz and some more clocks..
2)pll for the avalon bus + multiport fifos: that generates only 100Mhz.
the consumption was that the avalon bus will use the half clk rate = 200Mhz.
so if Im moving on DDR bus 32 bits( and its double rate so actually 64 bits) and from the avalon side we will move 128 bits on the multiport it will be in half rate(200Mhz).
but instead of using the 200Mhz for the avalon bus it uses the 100Mhz from the other pll and it doesnt make sense to me.
please explain to me why is that happening?
and if its ok, so why its ok?
BR,
Ram.
- AdzimZM_Altera
Hi Ram,
Thank you for submitting your question in Intel Community.
Can I have a look at the ddr3 example design that you are working with?
Adzim
- ramsoffer_123
Hi Adzim.
the design is very big.
I can't upload it here.
which part do you want me to send?
BR,
Ram.
- AdzimZM_Altera
Hi Ram,
You can provide the ddr example design in archive project file.
That file should be smaller.
Adzim
- AdzimZM_Altera
Hi Ram,
Is there any update on this thread?
Adzim
- AdzimZM_Altera
As we do not receive any response from you on the previous reply that we have provided, I now transition this thread to community support. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
