prmartinuk's avatar
prmartinuk
Icon for New Member rankNew Member
13 hours ago
Cyclone V CAN triple sampling
Does anyone know if the CAN controller on the Cyclone V implements the optional CAN feature of triple sampling?
There is no mention of it in the handbook or in the register definitions, so I am assuming that it just does the standard CAN functionality of single sampling.
But I wasn't sure if under the hood it was doing anything more complicated as some CAN controllers automatically do triple sampling at lower baud rates.
1 Reply
  • Hi,
    I cannot presently point to a Cyclone V HPS register definition or document explicitly proving triple sampling is implemented/enabled in Cyclone V HPS CAN. I will further check internally.
    Have you tried "$ ip -details link show can0"?
    If the Linux driver exposes: triple-sampling on/off
    then the underlying controller/driver combination should support it.
