AMa's avatar
AMa
6 years ago
Arria 10 SoC - Kernel load Failed. nRST output a low pulse.
The uboot load successful. When load kernel, the file system, dtb file, kernel all load correcy, the peripheral inistal success, but the kernel can not enter to shell, the last log is " ttyS0 - failed to request DMA", and the nRST pin output a low pulse.
Do you know, what is the reason about this low pulse on nRST Pin?
  • Hi,
    Firstly, may I know which Quartus version you are working on? Are you using our GHRD image for testing or your own design?
    If you are using your own deisgn, in Quartus/Platform designer, do you see any error reported?
  • AMa's avatar
    AMa
    The Quartus version is 18.1 Pro. There is no other peripheral in qsys sytem, just have the EMIF configuration, UART, QSPI Flash and EMAC.
    There is also no error in error report.
    I can attach my Quartus Project for you reference.
