AMa
6 years agoArria 10 SoC - Kernel load Failed. nRST output a low pulse.
The uboot load successful. When load kernel, the file system, dtb file, kernel all load correcy, the peripheral inistal success, but the kernel can not enter to shell, the last log is " ttyS0 - fail...
AMa
6 years agoThe attached is my project.
The linux kernel version is 4.1.22.
EBERLAZARE_I_Intel
6 years agoHi,
This kernel is old, have you try newer version of kernel to see if this improves the issue? Latest available version can be found here:
https://github.com/altera-opensource/linux-socfpga
Can you share your boot logs with the kernel logs as well?
