Agilex7m i have configure 4GB ddr linux is not booting. I got architect time failure error.
Agilex7m I have configure 2GB DDR, linux is booting fine. But if I configure 4GB ddr linux is not booting. I got architect time failure error. But 2GB ddr configuration this error not came.
I u-boot 4GB ddr is accessible but linux is not booting
Boot logs
init_mem_cal: Initial DDR calibration IO96B_0 succeed
DDR: Calibration success
is_mailbox_spec_compatible: IOSSM mailbox version: 1
DDR5: 4096 MiB
ecc_interrupt_status: ECC error number detected on IO96B_0: 0
DDR5: size check success
DDR5: firewall init success
DDR5 init success
QSPI: Reference clock at 500000 kHz
Trying to boot from SPI
Board ID is not in range 0 to 255
## Checking hash(es) for config board-0 ... OK
## Checking hash(es) for Image atf ... crc32+ OK
## Checking hash(es) for Image uboot ... crc32+ OK
## Checking hash(es) for Image fdt-0 ... crc32+ OK
NOTICE: BL31: v2.13.1(release):QPDS25.3.1_REL_GSRD_PR
NOTICE: BL31: Built : 10:40:22, Nov 25 2025
U-Boot 2025.10-ga0db71cfad37-dirty (Dec 11 2025 - 10:49:42 +0000)socfpga_agilex7m
CPU: Altera FPGA SoCFPGA Platform (ARMv8 64bit Cortex-A53)
Model: SoCFPGA Agilex7-M SoCDK
DRAM: 2 GiB (total 4 GiB)
Core: 38 devices, 22 uclasses, devicetree: separate
NAND: 0 MiB
MMC: mmc@ff808000: 0
Loading Environment from FAT... OK
In: serial@ffc02000
Out: serial@ffc02000
Err: serial@ffc02000
Net: eth0: ethernet@ff800000
Hit any key to stop autoboot: 0
SOCFPGA_AGILEX7M #
SOCFPGA_AGILEX7M #
SOCFPGA_AGILEX7M #
SOCFPGA_AGILEX7M # bdinfo
boot_params = 0x0000000000000100
DRAM bank = 0x0000000000000000
-> start = 0x0000000000000000
-> size = 0x0000000080000000
DRAM bank = 0x0000000000000001
-> start = 0x0000000100000000
flashstart = 0x0000000000000000
flashsize = 0x0000000000000000
flashoffset = 0x0000000000000000 baudrate = 115200 bps00 8N1 | NOR | Minicom 2.9 | VT102 | Offline | ttyACM0 relocaddr = 0x000000007fee9000
reloc off = 0x000000007fce9000
Build = 64-bit
current eth = ethernet@ff800000
ethaddr = b6:97:a4:21:e2:4a
IP addr = 169.254.65.121
fdt_blob = 0x000000007fae1950
lmb_dump_all:
memory.count = 0x2
memory[0] [0x0-0x7fffffff], 0x80000000 bytes, flags: none
memory[1] [0x100000000-0x17fffffff], 0x80000000 bytes, flags: none
reserved.count = 0x3
reserved[0] [0x0-0x1ffffff], 0x2000000 bytes, flags: no-map
reserved[1] [0x7eae1940-0x7fffffff], 0x151e6c0 bytes, flags: no-overwrite
reserved[2] [0x17fff7000-0x17fffffff], 0x9000 bytes, flags: no-notify, no-overwrite
devicetree = separate
serial addr = 0x00000000ffc02000
width = 0x0000000000000004
shift = 0x0000000000000002
clock = 0x0000000005f5e100
arch_number = 0x0000000000000000
TLB addr = 0x000000007ffe0000
irq_sp = 0x000000007fae1940
sp start = 0x000000007fae1940
Early malloc usage: 1608 / 2000
Failure log:
DDR5: 4096 MiB
DDR5 init success
Error: -22
Trying to boot from MMC1
U-Boot 2025.10 (Dec 11 2025 - 10:49:42 +0000)socfpga_agilex7m
NAND: 0 MiB
In: serial@ffc02000
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr.uimg
2411 bytes read in 3 ms (784.2 KiB/s)
## Executing script at 05ff0000
crc32+ Trying to boot Linux from device mmc0
Found kernel in mmc0
13661579 bytes read in 979 ms (13.3 MiB/s)
## Loading kernel (any) from FIT Image at 02000000 ...
Using 'board-0' configuration
Verifying Hash Integrity ... OK
Trying 'kernel' kernel subimage
Description: Linux Kernel
Type: Kernel Image
Compression: lzma compressed
Data Start: 0x020000dc
Data Size: 10439444 Bytes = 10 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x06000000
Entry Point: 0x06000000
Hash algo: crc32
Hash value: 0ccd8e20
Verifying Hash Integrity ... crc32+ OK
## Loading fdt (any) from FIT Image at 02000000 ...
Trying 'fdt-0' fdt subimage
Description: socfpga_socdk_vanilla
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x029f4cd4
Data Size: 32121 Bytes = 31.4 KiB
Hash algo: crc32
Hash value: 262d6a47
Booting using the fdt blob at 0x29f4cd4
Working FDT set to 29f4cd4
Uncompressing Kernel Image to 6000000
Loading Device Tree to 000000007ead6000, end 000000007eae0d78 ... OK
Working FDT set to 7ead6000
SF: Detected mt25qu02g with page size 256 Bytes, erase size 64 KiB, total 256 MiB
Enabling QSPI at Linux DTB...
libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
QSPI clock frequency updated
RSU: Firmware or flash content not supporting RSU
Starting kernel ...
Deasserting all peripheral resets
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.12.43-altera-gd16fc609d5a7 (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 14.3.0, GNU ld (GNU Binutils) 2.44.0.20250715) #1 SMP PREEMPT Tue Nov 25 16:06
:07 UTC 2025
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: SoCFPGA Agilex7-M SoCDK
[ 0.000000] efi: UEFI not found.
[ 0.000000] earlycon: uart0 at MMIO32 0x00000000ffc02000 (options '115200n8')
[ 0.000000] printk: legacy bootconsole [uart0] enabled
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000000000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node svcbuffer@0, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x0000000000000000..0x0000000001ffffff (32768 KiB) nomap non-reusable svcbuffer@0
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x000000017fffffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x17f7fbe80-0x17f7fe4bf]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000017fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000001ffffff]
[ 0.000000] node 0: [mem 0x0000000002000000-0x000000007fffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000017fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000017fffffff]
[ 0.000000] cma: Reserved 32 MiB at 0x000000007ca00000 on node -1
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.5
[ 0.000000] percpu: Embedded 25 pages/cpu s61784 r8192 d32424 u102400
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: earlycon panic=-1 root=/dev/mmcblk0p2 rw rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1048576
[ 0.000000] Policy zone: Normal
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x0000000078a00000-0x000000007ca00000] (64MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] timer_probe: no matching timers found
[ 0.000000] Kernel panic - not syncing: Unable to initialise architected timer.
[ 0.000000] CPU: 0 UID: 0 PID: 0 Comm: swapper/0 Not tainted 6.12.43-altera-gd16fc609d5a7 #1
[ 0.000000] Hardware name: SoCFPGA Agilex7-M SoCDK (DT)
[ 0.000000] Call trace:
[ 0.000000] dump_backtrace.part.0+0xd4/0xe0
[ 0.000000] show_stack+0x18/0x30
[ 0.000000] dump_stack_lvl+0x60/0x80
[ 0.000000] dump_stack+0x18/0x24
[ 0.000000] panic+0x168/0x360
[ 0.000000] time_init+0x30/0x50
[ 0.000000] start_kernel+0x544/0x6d0
[ 0.000000] __primary_switched+0x80/0x88
- KianHinT_altera
Dear Customer,
As we do not hear back from you for some time, we will transition this case to community support.
Altera Technical Support - KianHinT_altera
Hi Charan404 ,
May I ask what is the status for your issue, is it resolved already? Additionally , are you using 2 RAM slots or single slot for your 4GB?
Kian
- ScottP_Altera
Let me ask a couple questions to help me understand what the issue could be. U-boot is reporting:
It looks like a size mismatch. I'm wondering if you made the DDR size change to both the EMIF controller and to the u-boot device tree source? Are there any other changes?
