eharalanova
7 months agoAgilex 5E - PCIE PERST# pin - failing compilation
Hello! I'm using Critical Link MytiSom Dev Kit. It has the same FPGA as the Altera Dev Kit - A5ED065BB32AE6SR0. I'm adapting the PCIe Root Port example from Altera - I have assigned the PCIe Gen3x4 l...
eharalanova
2 months agoHello,
I found out, that the pins BE25 and BM28 are not connected to any reset on the board and are left floating. Can I tie high pin_perst_n and Pin_perst_n_1 (inputs to the PCIe HIP) in the logic? I use the PCIe in Root Port mode.
Thank you,
Eleonora
RongY_altera
Contributor
2 months agoNormally the perst_n of RP is used to drive perst_n of downstream EP. Given your situation, the only practical option is to tie them HIGH.
Rong
