eharalanova
7 months agoAgilex 5E - PCIE PERST# pin - failing compilation
Hello! I'm using Critical Link MytiSom Dev Kit. It has the same FPGA as the Altera Dev Kit - A5ED065BB32AE6SR0. I'm adapting the PCIe Root Port example from Altera - I have assigned the PCIe Gen3x4 l...
KelvinK_Altera
6 months agoHi eharalanova,
I would suggestion you to,
Check the Critical Link MitySom Dev Kit board schematic for the the Pin and IO
Make sure have the pin assign in the correct bank and correct voltage.
Ex. Altera Agilex 5 Premium Devkit using 3.3v for PERST.
Try to refer to the Critical Link guide on PCIe example design
https://support.criticallink.com/redmine/projects/mitysom_a5/wiki/Mitysom-a5e-pcie-gen3x4-ep
If you have more details share here with us.
