Agilex 5 EMAC GMII loopthrough: signals are not toggling in Fabric
Hello K606 ,
You may have a typo for the rx clock.
Could you please try this?
assign emac1_mac_rx_clk_wire = emac0_mac_tx_clk_o_wire; // 1GThank you.
- K60611 months ago
Contributor
Hi - so I changed this line. However, it seems the issue persists.
Do you know why this might be?
Please also note that the SoC system clocks are confirgured as followed:root@localhost:~# cat /sys/kernel/debug/clk/clk_summary enable prepare protect duty hardware clock count count count rate accuracy phase cycle enable ------------------------------------------------------------------------------------------------------- qspi-clk 1 1 0 200000000 0 0 50000 Y osc1 2 2 0 25000000 0 0 50000 Y periph_pll 1 1 0 2500000000 0 0 50000 Y peri_pll_c3 1 1 0 500000000 0 0 50000 Y psi_ref_free_clk 0 0 0 500000000 0 0 50000 Y psi_ref_clk 0 0 0 500000000 0 0 50000 Y s2f_user1_free_clk 0 0 0 500000000 0 0 50000 Y s2f_user1_clk 0 0 0 500000000 0 0 50000 Y s2f_user0_free_clk 0 0 0 500000000 0 0 50000 Y s2f_user0_clk 0 0 0 500000000 0 0 50000 Y emaca_free_clk 3 3 0 250000000 0 0 50000 Y emac2_clk 1 1 0 250000000 0 0 50000 Y emac1_clk 1 1 0 250000000 0 0 50000 Y emac0_clk 1 1 0 250000000 0 0 50000 YSo it seems the clocks are active, but when sending a 'ping' from EMAC0 to EMAC1 - there is no activity on the GMII lines in Fabric (even though it seems the ping is working in userland in the HPS)
root@localhost:~# sudo ip addr add 192.168.70.5/24 dev eth0 root@localhost:~# sudo ip addr add 192.168.70.1/24 dev eth1 root@localhost:~# ifconfig eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.70.5 netmask 255.255.255.0 broadcast 0.0.0.0 ether 3e:17:2e:db:8b:f6 txqueuelen 1000 (Ethernet) RX packets 60 bytes 19080 (19.0 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 168 bytes 27408 (27.4 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 23 eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.70.1 netmask 255.255.255.0 broadcast 0.0.0.0 ether 62:6f:4c:21:f2:f4 txqueuelen 1000 (Ethernet) RX packets 59 bytes 18762 (18.7 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 170 bytes 27588 (27.5 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 40 ... root@localhost:~# ping -I 192.168.70.1 192.168.70.5 PING 192.168.70.5 (192.168.70.5) from 192.168.70.1 : 56(84) bytes of data. 64 bytes from 192.168.70.5: icmp_seq=1 ttl=64 time=0.189 ms 64 bytes from 192.168.70.5: icmp_seq=2 ttl=64 time=0.034 ms 64 bytes from 192.168.70.5: icmp_seq=3 ttl=64 time=0.168 ms 64 bytes from 192.168.70.5: icmp_seq=4 ttl=64 time=0.042 ms 64 bytes from 192.168.70.5: icmp_seq=5 ttl=64 time=0.022 ms 64 bytes from 192.168.70.5: icmp_seq=6 ttl=64 time=0.009 ms 64 bytes from 192.168.70.5: icmp_seq=7 ttl=64 time=0.029 ms 64 bytes from 192.168.70.5: icmp_seq=8 ttl=64 time=0.020 ms 64 bytes from 192.168.70.5: icmp_seq=9 ttl=64 time=0.009 ms 64 bytes from 192.168.70.5: icmp_seq=10 ttl=64 time=0.034 ms 64 bytes from 192.168.70.5: icmp_seq=11 ttl=64 time=0.014 ms 64 bytes from 192.168.70.5: icmp_seq=12 ttl=64 time=0.012 ms 64 bytes from 192.168.70.5: icmp_seq=13 ttl=64 time=0.052 ms 64 bytes from 192.168.70.5: icmp_seq=14 ttl=64 time=0.025 ms 64 bytes from 192.168.70.5: icmp_seq=15 ttl=64 time=0.019 ms ^C --- 192.168.70.5 ping statistics --- 15 packets transmitted, 15 received, 0% packet loss, time 14335ms- ShunJingG_Altera11 months ago
hello,
thank you for the feedback.
May i know if ping is working before the change?
May i know what is the sampling clock for your signal tap?
For 1G speed you may need at least 250MHz sampling clock.- K60611 months ago
Contributor
So far, the ping has never produced GMII toggles on SignalTap.
I have also tried using a PLL generated 250MHz clock to measure on signal tap (as can be seen in the following diagrams).
In the following, I disconnected the loopback and instead added a 'dummy' rx packet generator - then sent them to the EMAC rxd wire via Fabric:
gmii_rx_test_pattern u_rx_pattern ( .rx_clk(emac1_mac_tx_clk_o_wire), .rstn(~system_reset), .rxd(emac0_mac_rxd_wire), .rx_dv(emac0_mac_rxdv_wire), .rx_er(emac0_mac_rxer_wire) );Which produces the following:
But it seems that on the Linux side these packets are not being acknowledged by the kernel:
root@localhost:~# cat /proc/net/dev Inter-| Receive | Transmit face |bytes packets errs drop fifo frame compressed multicast|bytes packets errs drop fifo colls card lo: 115040 1600 0 0 0 0 0 0 115040 1600 0 0 0 0 0 eth0: 0 0 0 0 0 0 0 0 9136 56 0 0 0 0 0 eth1: 0 0 0 0 0 0 0 0 9316 58 0 0 0 0 0 eth2: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0It also seems that sending ARPs do not produce GMII tx toggle in Fabric:
root@localhost:~# ifconfig eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.70.5 netmask 255.255.255.0 broadcast 0.0.0.0 ether ... RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 56 bytes 9136 (9.1 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 23 eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.71.1 netmask 255.255.255.0 broadcast 0.0.0.0 ether ... RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 67 bytes 9838 (9.8 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 40 root@localhost:~# sudo arping -I eth1 192.168.70.5 ARPING 192.168.70.5 Timeout Timeout ...
