Xcelium support for Agilex P-tile PCIe simulations
- 3 years ago
Hi Wincent,
Apologies for the delay in responding to your prior follow-up email.
Yes, you can close this ticket.
Thank you for the support.
Binu
Hi Binu,
Thanks for that,
We have some update in the newest version of Quartus, I am not sure that this able to solve the issue you seeing.
But the good start is you not seeing the earlier error anymore.
if you still seeing the same error using v23.2. Please sent me the .qar file together with any testbench file.
I will file this to related team.
Wincent_Intel
Hi Wincent,
I was finally able to get the simulation finishing and passing in Quartus 23.2_pro. So we will upgrade our internal version to 23.2_pro. I had to also put the IP in Gen5, 1x16, 1024 bit mode. Looks like that is one of the only 2 modes supported by example design.
Finally, I have couple of additional questions.
- Can you check and confirm if there are any fundamental functionality differences between a P-tile and R-tile IP?
- Say for example, if I generate a R-tile IP in Gen3,2x8 mode with TLP header enabled in GUI and this works in simulation, can I replace it with a P-tile Gen3, 2x8 mode IP later if needed and expect same functionality?
- Related to the above question, is the R-tile IP interface backward compatible to a P-tile IP interface?
Binu
