Xcelium support for Agilex P-tile PCIe simulations
- 3 years ago
Hi Wincent,
Apologies for the delay in responding to your prior follow-up email.
Yes, you can close this ticket.
Thank you for the support.
Binu
[Binu] I specifically asked this as the FPGA device mentioned in the link has 2 devices mentioned in Table2. The two devices are AGIB027R29A1E2VR3 or AGIB027R29A1E1VB. Table 1 only mentions one device AGIB027R29A1E2VR3. Please see link AGI027 eval kit and below screenshot for reference.
>> the OPN end with R3 is the latest silicon build, while the other is initial build.
If you need more information, you can contact the distributor/sales for the product specification.
[Binu] Today I hit the same error when I tried generating R-Tile IP targeting AGIB027R29A1E2VR3 and ran the Xcelium simulation. I am using Quartus Pro 23.1 and the 23.1 document says this device is supported.
- xmsim: *F,NOSNAP: Snapshot 'pcie_ed_tb.pcie_ed_tb' does not exist in the libraries.
>> yes, if refer to the user guide, it shall be supported. Can you please provide me the
1. Design .qar file
2. Printscreen of the error
I will file this to the development team, meanwhile can you try to generate a clean project and try it again if you seeing the same error ?
Wincent_Intel
Hi Wincent,
Thank you for the reply. I cleaned the project but that did not help. But I realised I missed some of the arguments/environment variables mentioned in https://www.intel.com/content/www/us/en/docs/programmable/683544/22-2-6-0-0/simulator-43921.html . Simulation seems to progress and looks like IP component was identified. But simulation was hanging after half an hour. So I kicked off again. Will let you know how that goes.
Do you know how long the simulation takes? Any ball park figure like 30 minutes, 1hour, 2hour?
Binu
- Wincent_Altera3 years ago
Hi Binu,
I check the internal document, by right R-tile with R3 OPN shall able to run simulation and it is supported.
I do not have the exact simulation time for this, but is shall be less than 2 hours for normal use, however in some case and situation if the design is large, it might take more time.
Wincent_intel
