Xcelium support for Agilex P-tile PCIe simulations
- 3 years ago
Hi Wincent,
Apologies for the delay in responding to your prior follow-up email.
Yes, you can close this ticket.
Thank you for the support.
Binu
Hi Wincent,
Thank you for following up.
I still would like to have more clarity on what I have understood so far. From what I see, there is NO Xcelium support for P-Tile IP as you pointed out. But I came across the limited Xcelium support on R-Tile based devices at https://www.intel.com/content/www/us/en/docs/programmable/683501/23-2-10-0-0/features.html
I also see that the AGI027 Agilex board may be populated with one of 2 devices(AGIB027R29A1E2VR3 or AGIB027R29A1E1VB) as mentioned in https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/agi027.html. Are you able to advise which device gets populated on this board? Is it based on customer request or part availability?
The reason I am asking this is, if AGI027 gets populated with AGIB027R29A1E2VR3, I believe Xcelium will be supported for that device/board as it matches the highlighted item/OPN in below screenshot.
Binu
