11 years ago
Wrong node type for node in vector source file (vhdl file). Jk flop
Design node type is of Output type but in signal in vector file is bidirectional. (QUARTUS II)
My code for a JK flip flop compiles correctly but the problem I am having is that when I try to run simulation, an error occurs. I've been troubleshooting/debugging for 2 days now with no luck. Any advice?
entity jkflop is
port (
j,k,clk,pre,clr: in bit;
q, qn: out bit);
end jkflop;
architecture behavior of jkflop is
begin
PROCESS(clk,pre,clr)
variable q1: bit;
begin
if pre = '0' then
q1:= '1';
elsif clr = '0' then
q1:= '0';
elsif (clk 'event AND clk = '0') then
if (j = '0' AND k = '0') then
q1:= q1;
elsif (j = '1' AND k = '0') then
q1:= '1';
elsif (j = ''0' AND k = '1') then
q1:= '0';
else
q1:= NOT q1;
END if;
END if;
q<= q1;
qn<= NOT q1;
END PROCESS;
END behavior;
    --- Quote Start ---
    What error is occurring
    --- Quote End ---
    Warning: Wrong node type for node "q" in vector source file. Design node is of type Output, but signal in vector source file is of type Bidir.
    Error: Can't simulate mismatched node types.
    Warning: Wrong node type for node "qn" in vector source file. Design node is of type Output, but signal in vector source file is of type Bidir.
    Any time I run my simulation, I receive those warning. My outputs q and qn show unknown values, my simulated results page takes my end time from 1us to 10us, and my inputs have all changed per that results page as well.
    I don't think half of that stuff is an issue, except for the node type problem....that is what I am trying to solve.
    Your vwf isnt setup correctly. I highly suggest you write your own testbench rather than try and use a VWF file for testing.
