8 years ago
Writing a host application that does not need to reprogram the FPGA
Hello community,
I am working on a project that requires the ability to run a host application on an OpenCL Kernel without programming the device during the execution of the host application. In other words, I would like to program the device once using:
aocl program acl0 vector_add.aocx
And then I would like to run the associate host program multiple times without it reprogramming the device as seen below:
Initializing OpenCL
Platform: Intel(R) FPGA SDK for OpenCL(TM)
Using 1 device(s)
  de5net_a7 : Terasic's Preferred Board
Using AOCX: vector_add.aocx
Reprogramming device  with handle 1
It is my understanding that clcreateprogramwithbinary(...) is the OpenCL API call that programs the device. But I am wondering if there is any way around this? Can I create a program without reprogramming the device if it is already ready programmed with the target image? If I don't make this API call, I get "CL_INVALID_PROGRAM" later on in the execution of the host application.
This example uses the vector_add OpenCL design from Intel.
I know that "aocl diagnose acl0" is able to write to / read from global memory (DDR on the FPGA board) without reprogramming the device, but that does not exercise the kernel.
Thanks ahead of time. I am new to OpenCL, but I am very impressed with what this tool can do.
    You can use "export CL_CONTEXT_COMPILER_MODE_ALTERA=3" to disable run-time reconfiguration. I regularly use this when benchmarking to prevent the FPGA from being reprogrammed every time. Just be careful that if you need to use run-time reconfiguration again, you must unset that environmental variable. It has happened to me multiple times that I forgot to unset it and a few days later tried to run a new kernel on the FPGA and was scratching my head for half an hour trying to figure out why I get "CL_INVALID_KERNEL_ARGS". :D
    HRZ, thank you! I have been looking for this solution for about a month now... Doing what you mentioned worked perfectly. I am working with Quartus Prime 18.0 and a polite WARNING came up saying "CL_CONTEXT_COMPILER_MODE_ALTERA" is deprecated, please use "CL_CONTEXT_COMPILER_MODE_INTELFPGA". Either way it worked, but using the new variable name removed the warning.
    Also for future readers, thanks to HRZ, I finally ran into this: https://www.altera.com/documentation/ewa1404851957878.html#ewa1405368788074 . It is the troubleshooting section of the Stratix V OpenCL porting guide. It lists environment variables and their functionality including this environment variable. From that page:
    Unset this variable or set it to a value of 3. The OpenCL™ host runtime reprograms the FPGA as needed, which it does at least once during initialization. To prevent the host application from programming the FPGA, set this variable to a value of 3.
    Important: When setting CL_CONTEXT_COMPILER_MODE_INTELFPGA, only use a value of 3.
    Life saver. Thanks again.
    Oh, yes, I am still using the "pre-Intel" versions of the compiler. :D
    • forto1's avatar
      forto1
      I am using the Cyclone V - DE10 nano Kit with FPGA SDK 16.1.
      Where I set CL_CONTEXT_COMPILER_MODE_INTELFPGA=3? Is it possible?
      • HRZ's avatar
        HRZ
        Since you are using a pre-Intel version of the compiler, just run "export CL_CONTEXT_COMPILER_MODE_ALTERA=3" from command line. Note that you must configure the FPGA manually using "aocl program" first.
        When you are done, you should run "unset CL_CONTEXT_COMPILER_MODE_ALTERA" from command line if you want to go back to the default method of run-time reconfiguration by the host code.
