8 years agoWriting a host application that does not need to reprogram the FPGA
Hello community, I am working on a project that requires the ability to run a host application on an OpenCL Kernel without programming the device during the execution of the host application. I...
forto1
6 years agoI am using the Cyclone V - DE10 nano Kit with FPGA SDK 16.1.
Where I set CL_CONTEXT_COMPILER_MODE_INTELFPGA=3? Is it possible?
HRZ
6 years agoSince you are using a pre-Intel version of the compiler, just run "export CL_CONTEXT_COMPILER_MODE_ALTERA=3" from command line. Note that you must configure the FPGA manually using "aocl program" first.
When you are done, you should run "unset CL_CONTEXT_COMPILER_MODE_ALTERA" from command line if you want to go back to the default method of run-time reconfiguration by the host code.
