8 years agoWriting a host application that does not need to reprogram the FPGA
Hello community, I am working on a project that requires the ability to run a host application on an OpenCL Kernel without programming the device during the execution of the host application. I...
8 years agoYou can use "export CL_CONTEXT_COMPILER_MODE_ALTERA=3" to disable run-time reconfiguration. I regularly use this when benchmarking to prevent the FPGA from being reprogrammed every time. Just be careful that if you need to use run-time reconfiguration again, you must unset that environmental variable. It has happened to me multiple times that I forgot to unset it and a few days later tried to run a new kernel on the FPGA and was scratching my head for half an hour trying to figure out why I get "CL_INVALID_KERNEL_ARGS". :D
