--- Quote Start --- When I use ModelSim-Altera to do simulation, I run modelsim from Quartus II using Tool-> Run EDA Simulation Tool -> EDA Gate Level Simulation. Then there are three options: Slow-81.2V 85 Model Slow-81.2V 0 Model Fast-M 1.2V 0 Model I just wonder what is difference between them and how can I decide which one I should use? --- Quote End --- All three. Your systems should be designed to be robust over all process, voltage, and temperature variation (also known as PVT). http://en.wikipedia.org/wiki/process_corners These three timing models are different PVT setups. Cheers, Dave - Altera_Forum
Thanks very much, Dave! I will read the link you give. And do you know can we estimate the power consumption of our design in Quartus II after completed compilation?
Thanks! - Altera_Forum
--- Quote Start --- And do you know can we estimate the power consumption of our design in Quartus II after completed compilation? --- Quote End --- You write a testbench that enables the design as you intend to use it, i.e., with realistic traffic on its I/Os, and realistic processing using internal logic. You run this testbench in Modelsim and create a Value Change Dump (.vcd) file. Then use Altera's power analysis tool to get a power estimate (I think that's right, its been a while since I've done it). Depending on the FPGA you are using, you need a machine with a huge amount of memory. For the Stratix II design I was working with, I ended up created designs with 5%, 10%, 20%, 30% of the logic I planned on using in the final design, and then extrapolated to a full FPGA. For a worst-case power analysis, you can create a Qsys system with blocks of registers that you can enable to toggle their outputs. You can create a block size that is say 5% of a device, and then enable one block for a 5% power load, two blocks for 10%, etc. Cheers, Dave
