13 years ago --- Quote Start --- When I use ModelSim-Altera to do simulation, I run modelsim from Quartus II using Tool-> Run EDA Simulation Tool -> EDA Gate Level Simulation. Then there are three options: Slow-81.2V 85 Model Slow-81.2V 0 Model Fast-M 1.2V 0 Model I just wonder what is difference between them and how can I decide which one I should use? --- Quote End --- All three. Your systems should be designed to be robust over all process, voltage, and temperature variation (also known as PVT). http://en.wikipedia.org/wiki/process_corners These three timing models are different PVT setups. Cheers, Dave
