I don't understand it.
It may help it you told where it came from. - Altera_Forum
--- Quote Start --- I don't understand it. It may help it you told where it came from. --- Quote End --- I'm find: http://support.aldec.com/knowledgebase/article.aspx?aid=000786&show=vsa00219.htm --- Quote Start --- Indexed part-selects are supported. For vectors where the msb is less than the lsb (e.g. [0:15]) the following syntax is used: little_vec [msb_base_expr +: width_expr] This selects the width_expr number of bits starting from bit msb_base_expr. The bit range is ascending. The [2 +: 3] part-select selects bits [2:4] (i.e. three bits starting from bit 2). For vectors where the msb is greater than the lsb (e.g. [15:0]) the following syntax is used: big_vec [msb_base_expr -: width_expr] This selects the width_expr number of bits starting from bit msb_base_expr. The bit range is descending. The [4 -: 3] part-select selects bits [4:2] (i.e. three bits starting from bit 4). Expressions used in indexed part-selects must be constant expressions. This is a limitation of the current version of the simulator. LRM allows that the msb_base_exp and the lsb_base_exp vary at run time. --- Quote End --- - Altera_Forum
You give the anwser to your question ;)
The first number is the bit to start from, then the +/- gives the direction, and the second number gives the number of bits. Therefore [10+:4] means [10:13] and [10-:4] means [10:7] I didn't know this kind of construction in Verilog, and I wonder if it wouldn't add confusion to a code if you start mixing it with the traditionnal vector representation... - Altera_Forum
--- Quote Start --- I didn't know this kind of construction in Verilog, and I wonder if it wouldn't add confusion to a code if you start mixing it with the traditionnal vector representation... --- Quote End --- The main reason for use it is
After I can add more registers to regs.io.rw without changing anything else.genvar j; generate for(j=$bits(regs.io.rw);j!=0;j=j-64)begin : rw_regs int k=($bits(regs.io.rw)-j)/64; assign data = (tx_data_valid && (cpld_from.addr == {BASE_ADDR_RW,k}) )?regs.io.rw:{64{1'bz}}; end endgenerate
