15 years ago --- Quote Start --- I didn't know this kind of construction in Verilog, and I wonder if it wouldn't add confusion to a code if you start mixing it with the traditionnal vector representation... --- Quote End --- The main reason for use it is
genvar j;
generate
for(j=$bits(regs.io.rw);j!=0;j=j-64)begin : rw_regs
int k=($bits(regs.io.rw)-j)/64;
assign data = (tx_data_valid && (cpld_from.addr == {BASE_ADDR_RW,k}) )?regs.io.rw:{64{1'bz}};
end
endgenerate After I can add more registers to regs.io.rw without changing anything else.
