yemo's avatar
yemo
1 year ago
Wavform Simulator Error: Invalid Licese Environment
I installed Quartus II 24.1 Lite Edition. When using waveform simulator, I found the error:
*** Running the ModelSim simulation **** c:/altera_lite/24.1std/questa_fse/win64//vsim -c -do test.do **
Fatal: Failed to initialize licensing environment. License environment not set correctly. Unable to checkout a license. Vsim is closing. ** Error: Invalid license environment. Application closing. Error.
Everything was fine before this error.
I have allready fixed my license to Quartus II in options-License Setup.Maybe my question is too basic to be answered but I have tried every method I could think about. Thank you.
  • sstrell's avatar
    sstrell
    Is your LM_LICENSE_FILE environment variable pointing to your license file?
  • yemo's avatar
    yemo
    LM_LICENSE_FILE environment variable is set correctly and I can see the simulation result but the output is unkonwn(XXXX).
    ls138.v
    module ls138(G1,G2A,G2B,A,Y);
    input G1,G2A,G2B;
    input [2:0] A;
    output [7:0] Y;
    reg [7:0] Y;
    always@(G1 , G2A , G2B , A)
    begin
    if(G1&&(!G2A)&&(!G2B))
    begin
    case (A)
    3'b000: Y<=8'b1111_1110;
    3'b001: Y<=8'b1111_1101;
    3'b010: Y<=8'b1111_1011;
    3'b011: Y<=8'b1111_0111;
    3'b100: Y<=8'b1110_1111;
    3'b101: Y<=8'b1101_1111;
    3'b110: Y<=8'b1011_1111;
    3'b111: Y<=8'b0111_1111;
    default: Y<=8'b1111_1111;
    endcase
    end
    else
    Y<=8'b1111_1111;
    end
    endmodule
    simulaotion result is attached.
  • RichardT_altera's avatar
    RichardT_altera
    Seem like a tool limitation with the Simulation Waveform Editor.
    Try to run using our Questa Intel FPGA Starter Edition simulation tool. The tool should be able to provide the output data.
    Richard Tan
    • yemo's avatar
      yemo
      Can you explain the process in detail?
    RichardT_altera
    Since you are using Quartus Lite, we have a quick start manual on how to run the Questa tool using the Nativelink simulation flow (only in Quartus Lite/Std edition).
    You can download the example design and give it a run.
    Once you are familiar with the simulation flow, try this with your own design and testbench.
    https://www.intel.com/content/www/us/en/docs/programmable/703090/21-1/simulation-quick-start.html
    Richard Tan
    RichardT_altera
    Any update on this?
    Do you able to simulate using the Questa Intel FPGA Starter Edition?
    Richard Tan
    • yemo's avatar
      yemo
      Sorry, something occurred these days and it took all mind. My problem is solved and thank you for your patience and notice.
    RichardT_altera
    Thank you for acknowledging the solution provided. I'm pleased to know that your question has been addressed.
    Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
    Richard Tan
