yemo
1 year agoWavform Simulator Error: Invalid Licese Environment
I installed Quartus II 24.1 Lite Edition. When using waveform simulator, I found the error: *** Running the ModelSim simulation **** c:/altera_lite/24.1std/questa_fse/win64//vsim -c -do test.do ** ...
- 1 year ago
Since you are using Quartus Lite, we have a quick start manual on how to run the Questa tool using the Nativelink simulation flow (only in Quartus Lite/Std edition).
You can download the example design and give it a run.
Once you are familiar with the simulation flow, try this with your own design and testbench.
https://www.intel.com/content/www/us/en/docs/programmable/703090/21-1/simulation-quick-start.html
Richard Tan
RichardT_altera
1 year agoSeem like a tool limitation with the Simulation Waveform Editor.
Try to run using our Questa Intel FPGA Starter Edition simulation tool. The tool should be able to provide the output data.
Richard Tan
- yemo1 year ago
Can you explain the process in detail?
