14 years agoWarning: No paths found for timing analysis
I'm writing a spi module,just a receiver. Few lines,but many warnings.
The total logic elements is 0%. Can an get a answer about how to result the problem? Code: module spi (input clk, input cs, input sdi, output reg getdata, output reg [7:0] recbuf ); reg stsig = 0; reg [3:0] reccount = 7; always @(cs) if(sdi) stsig = 0; else stsig = 1; always @(posedge clk) begin if(stsig && reccount<8) begin recbuf[reccount] = sdi; reccount = reccount - 1; end else begin reccount = 7; getdata = 1; end end endmodule Warnings: Warning: Output pins are stuck at VCC or GND Warning: Design contains 3 input pin(s) that do not drive logic Warning: No exact pin location assignment(s) for 12 pins of 12 total pins Warning: Following 9 pins have nothing, GND, or VCC driving datain port -- changes to this connectivity may change fitting results Warning: The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'. Warning: No paths found for timing analysis
