annamalairaj's avatar
annamalairaj
10 months ago
Minimum pulse width violation on EMIF-HPS
We are observing Minimum pulse width summary violation on three clocks in EMIF. Snapshots of Minimum pulse width violation on each of these clocks are attached.
Quartus version: 25.1.1
targeted FPGA: AGFB027R24C2E3V
Please share your suggestions.
  • AdzimZM_Altera's avatar
    AdzimZM_Altera
    I have a few questions below, please help to provide your feedback.
    1. Can you share the connection of the EMIF HPS IP in Platform Designer?
    2. What is the clock frequency you set in EMIF HPS IP?
    3. Is there any SDC has been set to target this clock?
    4. Is there any other IP than EMIF HPS IP in IO Bank 3C and 3D?
    5. Are you sharing the reference clock source for EMIF HPS IP?
    Adzim
    • annamalairaj's avatar
      annamalairaj
      Hi AdzimZM_Altera​
      Sorry for the delayed response, and thanks for your patience. I wasn't able to follow up earlier. Regarding your questions:
        • Attached the image (emif_hps.png).
        • 1200 MHz
        • No.
        • No, IO Bank 3C and 3D are dedicated only for EMIF HPS IP.
        • No, we are not sharing this clock with any other blocks.
  • Hi AdzimZM_Altera​
    I have used Superior Performance with Maximum Placement Effort performance option and also tried the EMIF document optimize timing method by updating the Placement Effort Multiplier to 2 still same violation is observed.
    I have also attached the HPS subsystem files.
      AdzimZM_Altera
      hi annamalairaj
      I make hps_subsys as a top level, set the hps bridge as virtual pin and compile the design.
      I don't get the timing violation as you see.
      Can you try that from your end?
