Warning in GTS AXI Streaming IP for PCIe generated example
I have generated the example design for the GTS AXIS Streaming IP for PCIe and I notice that there is a warning in platform designer:
Component Instantiation Warning: hipim_platform.rst_ctrl_for_gts_pcie_0: Warnings found in IP parameterization.
Component Instantiation Warning: pcie_ed.pio0: Warnings found in IP parameterization.What is the reason for this warning?
Is it possible to glean more information about any potential issue that the warning is highlighting?
Image of the warning in platform designer:
1 Reply
- ai_responder
Community Manager
These are three distinct warnings visible in your screenshot, all of which have documented explanations.
1. Component Instantiation Warning — "Warnings found in IP parameterization" (pcie_ed.pio0, rst_ctrl_for_gts_pcie_0)
When component instantiation values do not match the component's corresponding.ipfile, Platform Designer reports these mismatches as Component Instantiation Warnings in the System Messages tab. You must synchronize any mismatches between the component instantiation and the component's corresponding.ipprior to system generation. 1.14. Synchronizing System Component Information — Quartus® Prime Pro Edition User Guide
To dig into the root cause: follow these steps to synchronize: select the mismatched signal or interface in the System View tab, and then click View ➤ System Info. Alternatively, you can double-click the corresponding Component Instantiation Warning in the System Messages tab. 1.14. Synchronizing System Component Information — Quartus® Prime Pro Edition User Guide Once you open System Info, it lists the signals and interfaces for the selected component with respect to the component instantiation. Value mismatches between the Component Instantiation and the IP file appear in blue. Missing elements appear in green. Table 18. System Info Tab Fields — Quartus® Prime Pro Edition User Guide
2. System Connectivity Warning — "No synchronous edges, but has associated clock" (pcie_ed.pio0.pio_pin_perst_n)
This is the PERST# reset input signal. A warning similar to "No synchronous edges, but has associated clock" may appear. The warning is mistakenly issued for resetrequest signals associated with a clock, with synchronousEdges set to NONE. The clock association is required for proper connection of the resetrequest. You may ignore the displayed warning. SOPC Builder Issues Erroneous Error Message
Additionally, this warning appears when using certain timer/peripheral components in the Qsys System Integration Tool. It is safe to ignore this warning. Warning: unsaved.watchdog.resetrequest: No synchronous edges, but has associated clock
3. System Connectivity Warning — "p0_lite_csr is not connected to a MM host or exported" (pcie_ed.dut)
This is a legitimate connectivity warning. Thep0_lite_csris the AXI4-Lite CSR interface on the GTS AXI Streaming IP. The Control and Status Register interface is an AXI4-lite Manager interface with a 20-bit address bus and a 32-bit data bus. The GTS AXI MCDMA IP uses this interface to access registers implemented in the GTS AXI Streaming IP, allowing the user application to access PCIe configuration space registers of all Functions as well as soft register space registers. This interface can be used in Endpoint and Root Port modes, and is connected to the Control and Status Register Responder Interface of the GTS AXI Streaming IP.
If you are using the standalone PIO design example (without the GTS AXI MCDMA IP),p0_lite_csrwill not have an internal manager driving it. For the user logic to access registers of the GTS AXI Streaming IP, the Enable HIP Reconfiguration Interface parameter can be enabled to expose an AXI4-lite Subordinate interface. The application accesses PCIe configuration space registers through this interface by adding an offset of 0x80000 to the actual physical address of the PCIe configuration space address. 6. Validating the IP — GTS AXI Multichannel DMA IP for PCI Express* User Guide If you do not need register access in your design example, the warning is expected and can be suppressed by either exporting the interface to the top level or leaving it disconnected if CSR access is not required.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
