PixelPusher's avatar
PixelPusher
1 hour ago
QuartusIQ MCP Knowledge base and docs search intermittently timing out
Hi, I have started trying out the QuartusIQ MCP in VS code to search through knowledge base and docs faster using an AI model. I have noticed that the docs and knowledge search times out around 60% of the time, so I need to repeatedly re-query the database until it succeeds.
It looks like the client timeout of 25 seconds is too low for the amount of time it takes to receive a response from the Altera server. Is there any way to increase the timeout? It looks like it could be based on server / network load because sometimes it works 100% of the time
I am using altera.quartus-mcp version 0.5.6 with the VS code copilot integration. VS code version 1.146, I am running through VS code under WSL.
I have attached an excerpt from the MCP logs
1 Reply
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
