11 years agoVirtual JTAG counter to TDO
Hi everyone,
I'm new in FPGA verilog system. I have a DE0 nano from Terasic (http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&no=593&from=fb-like). During my little training (principally on the internet), I heard about the virtual JTAG. After searching examples and Altera documents, I create a project where I would like us the vJTAG. I create a simple counter where I implement a virtual JTAG to see which value this counter have. My counter work correctly, and I can communicate with FPGA. But I have a little problem and I can not resolve it. When the value of my counter go to TDO, I read a read a wrong value (when I have 0000 0001, I have 0000 0010). I really don't understand. Maybe I do something wrong and miss something in the process of the vJTAG. Here is my code : Verilog code :
module vjiInterface(
input out_data,
output reg visual
wire tck, tdi;
reg tdo;
wire ir_in;
wire ir_out;
wire v_cdr, v_sdr,v_udr,v_e1dr,v_pdr,v_e2dr,v_cir,v_uir;
reg dr1_tmp_reg =0;
assign ir_out = ir_out;
reg cdr_delayed, sdr_delayed;
myVJI myVJI(
.tdi(tdi),
.tdo(tdo),
.ir_in(ir_in),
.ir_out(ir_out),
.virtual_state_cdr(v_cdr),
.virtual_state_sdr(v_sdr),
.virtual_state_e1dr(v_e1dr),
.virtual_state_pdr(v_pdr),
.virtual_state_e2dr(v_e2dr),
.virtual_state_udr(v_udr),
.virtual_state_cir(v_cir),
.virtual_state_uir(v_uir),
.tck(tck)
always @(negedge tck)
begin
cdr_delayed = v_cdr;
sdr_delayed = v_sdr;
end
always @(posedge tck)
begin
case (ir_in)
00 :
begin
if (cdr_delayed)
begin
dr1_tmp_reg = out_data;
visual = dr1_tmp_reg;
end
else
begin
if(sdr_delayed)
tdo = dr1_tmp_reg;
dr1_tmp_reg = {dr1_tmp_reg,dr1_tmp_reg};
end
end
endcase
end
endmodule
TCL code (part where I catch data from TDO)
proc recv {} {
device_virtual_ir_shift -instance_index 0 -ir_value 0 -no_captured_ir_value
set tdi
return $tdi
Visualization : Counter value : 0000 0011 / and after a TDO operation : 0000 0110 http://www.alteraforum.com/forum/attachment.php?attachmentid=10461&stc=1 Thanks for the help. Sorry for my english's mistakes. Hellikandra4 Replies
I do another test. And with a simple shift register Parallel in serial out, all work correctly. I have changed a part of my code I work every positive edge clock. But nothing change.
Is the TDO do a first one bit shift before sending information ?always @(posedge tck) begin case (ir_in) 00 : begin if (v_cdr) begin dr1_tmp_reg = out_data; visual = dr1_tmp_reg; end else begin if(v_sdr) tdo = dr1_tmp_reg; dr1_tmp_reg = {dr1_tmp_reg,dr1_tmp_reg}; end end endcase end - Altera_Forum
This is the code easier :
It's not look like this code (from "Virtual JTAG Megafunction (sld_virtual_jtag) but here we put a value in the counter.module counterVjtag( // input input clock50, input key0, // reset for counter // output output blinkLed ); assign blinkLed= catchValue; assign blinkLed= catchValue; assign blinkLed= catchValue; assign blinkLed= catchValue; assign blinkLed= catchValue; assign blinkLed= catchValue; assign blinkLed= catchValue; assign blinkLed= catchValue; // counter reg & wire wire clk001; reg bigCounter; reg catchValue; myPLL myPLL( .inclk0(clock50), .c0(clk001) // clock @ 10kHz ); // virtual JTAG reg & wire reg tdo; wire ir_in,ir_out; wire tck; wire v_cdr,v_sdr; reg dr1_tmp_reg; assign ir_out = ir_in; myvirtualJTAG myvirtualJTAG( // input .tdo(tdo), .ir_out(ir_out), // // output .tdi(), .ir_in(ir_in), // .virtual_state_cdr(v_cdr), .virtual_state_sdr(v_sdr), .virtual_state_e1dr(), .virtual_state_pdr(), .virtual_state_e2dr(), .virtual_state_udr(), .virtual_state_cir(), .virtual_state_uir(), .tms(), .jtag_state_tlr(), .jtag_state_rti(), .jtag_state_sdrs(), .jtag_state_cdr(), .jtag_state_sdr(), .jtag_state_e1dr(), .jtag_state_pdr(), .jtag_state_e2dr(), .jtag_state_udr(), .jtag_state_sirs(), .jtag_state_cir(), .jtag_state_sir(), .jtag_state_e1ir(), .jtag_state_pir(), .jtag_state_e2ir(), .jtag_state_uir(), .tck(tck) ); always @(posedge clk001) begin if (key0) begin bigCounter = bigCounter + 1; catchValue = bigCounter ; end else bigCounter = 0; end always @(posedge tck) begin case (ir_in) 0 : begin if(v_cdr) dr1_tmp_reg = catchValue; else if(v_sdr) begin tdo = dr1_tmp_reg; dr1_tmp_reg = dr1_tmp_reg >> 1; end end endcase end endmodulemodule counter (clock, my_counter); input clock; output my_counter; reg my_counter; always @ (posedge clock) if (load && e1dr) // decode logic: used to load the counter my_counter my_counter <= tmp_reg; else my_counter <= my_counter + 1; // Signals and registers declared for VJI instance wire tck, tdi; reg tdo; wire cdr, eldr, e2dr, pdr, sdr, udr, uir, cir; wire ir_in; // Instantiation of VJI my_vji VJI_INST( .tdo (tdo), .tck (tck), .tdi (tdi), .tms(), .ir_in(ir_in), .ir_out(), .virtual_state_cdr (cdr), .virtual_state_e1dr(e1dr), .virtual_state_e2dr(e2dr), .virtual_state_pdr (pdr), .virtual_state_sdr (sdr), .virtual_state_udr (udr), .virtual_state_uir (uir), .virtual_state_cir (cir) ); // Declaration of data register reg tmp_reg; // Deocde Logic Block // Making some decode logic from ir_in output port of VJI wire load = ir_in && ~ir_in; // Bypass used to maintain the scan chain continuity for // tdi and tdo ports bypass_reg <= tdi; // Data Register Block always @ (posedge tck) if ( load && sdr ) tmp_reg <= {tdi, tmp_reg}; // tdo Logic Block always @ (tmp_reg or bypass_reg) if(load) tdo <= tmp_reg else tdo <= bypass_reg; endmodule - Altera_Forum
Sorry to come back to you....
Someone have an idea ? I search again and again. If I ceate an FIFO instance, Is it possible that resolve my problem ? And how can I implement that in my design ? Thanks for helping - Altera_Forum
Try output to tdo with combinational design.
E.g. assign tdo = (sdr_delayed)? dr1_tmp_reg[0] : 1'b0; and shift the dr1_tmp_reg on tck rising edge as what you did in your code --- Quote Start --- Hi everyone, I'm new in FPGA verilog system. I have a DE0 nano from Terasic (http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&no=593&from=fb-like). During my little training (principally on the internet), I heard about the virtual JTAG. After searching examples and Altera documents, I create a project where I would like us the vJTAG. I create a simple counter where I implement a virtual JTAG to see which value this counter have. My counter work correctly, and I can communicate with FPGA. But I have a little problem and I can not resolve it. When the value of my counter go to TDO, I read a read a wrong value (when I have 0000 0001, I have 0000 0010). I really don't understand. Maybe I do something wrong and miss something in the process of the vJTAG. Here is my code : Verilog code :
TCL code (part where I catch data from TDO)module vjiInterface( input out_data, output reg visual ); wire tck, tdi; reg tdo; wire ir_in; wire ir_out; wire v_cdr, v_sdr,v_udr,v_e1dr,v_pdr,v_e2dr,v_cir,v_uir; reg dr1_tmp_reg =0; assign ir_out = ir_out; reg cdr_delayed, sdr_delayed; myVJI myVJI( .tdi(tdi), .tdo(tdo), .ir_in(ir_in), .ir_out(ir_out), .virtual_state_cdr(v_cdr), .virtual_state_sdr(v_sdr), .virtual_state_e1dr(v_e1dr), .virtual_state_pdr(v_pdr), .virtual_state_e2dr(v_e2dr), .virtual_state_udr(v_udr), .virtual_state_cir(v_cir), .virtual_state_uir(v_uir), .tck(tck) ); always @(negedge tck) begin cdr_delayed = v_cdr; sdr_delayed = v_sdr; end always @(posedge tck) begin case (ir_in) 00 : begin if (cdr_delayed) begin dr1_tmp_reg = out_data; visual = dr1_tmp_reg; end else begin if(sdr_delayed) tdo = dr1_tmp_reg; dr1_tmp_reg = {dr1_tmp_reg,dr1_tmp_reg}; end end endcase end endmodule
Visualization : Counter value : 0000 0011 / and after a TDO operation : 0000 0110 http://www.alteraforum.com/forum/attachment.php?attachmentid=10461&stc=1 Thanks for the help. Sorry for my english's mistakes. Hellikandra --- Quote End ---proc recv {} { device_virtual_ir_shift -instance_index 0 -ir_value 0 -no_captured_ir_value set tdi return $tdi }
