11 years agoVirtual JTAG counter to TDO
Hi everyone, I'm new in FPGA verilog system. I have a DE0 nano from Terasic (http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&no=593&from=fb-like). During my little train...
11 years agoThis is the code easier :
module counterVjtag(
// input
input clock50,
input key0, // reset for counter
// output
output blinkLed
assign blinkLed= catchValue;
// counter reg & wire
wire clk001;
reg bigCounter;
reg catchValue;
myPLL myPLL(
.inclk0(clock50),
.c0(clk001) // clock @ 10kHz
// virtual JTAG reg & wire
reg tdo;
wire ir_in,ir_out;
wire tck;
wire v_cdr,v_sdr;
reg dr1_tmp_reg;
assign ir_out = ir_in;
myvirtualJTAG myvirtualJTAG(
// input
.tdo(tdo),
.ir_out(ir_out), //
// output
.tdi(),
.ir_in(ir_in), //
.virtual_state_cdr(v_cdr),
.virtual_state_sdr(v_sdr),
.virtual_state_e1dr(),
.virtual_state_pdr(),
.virtual_state_e2dr(),
.virtual_state_udr(),
.virtual_state_cir(),
.virtual_state_uir(),
.tms(),
.jtag_state_tlr(),
.jtag_state_rti(),
.jtag_state_sdrs(),
.jtag_state_cdr(),
.jtag_state_sdr(),
.jtag_state_e1dr(),
.jtag_state_pdr(),
.jtag_state_e2dr(),
.jtag_state_udr(),
.jtag_state_sirs(),
.jtag_state_cir(),
.jtag_state_sir(),
.jtag_state_e1ir(),
.jtag_state_pir(),
.jtag_state_e2ir(),
.jtag_state_uir(),
.tck(tck)
always @(posedge clk001)
begin
if (key0)
begin
bigCounter = bigCounter + 1;
catchValue = bigCounter ;
end
else
bigCounter = 0;
end
always @(posedge tck)
begin
case (ir_in)
0 :
begin
if(v_cdr)
dr1_tmp_reg = catchValue;
else
if(v_sdr)
begin
tdo = dr1_tmp_reg;
dr1_tmp_reg = dr1_tmp_reg >> 1;
end
end
endcase
end
endmodule
It's not look like this code (from "Virtual JTAG Megafunction (sld_virtual_jtag) but here we put a value in the counter.
module counter (clock, my_counter);
input clock;
output my_counter;
reg my_counter;
always @ (posedge clock)
if (load && e1dr) // decode logic: used to load the counter my_counter
my_counter <= tmp_reg;
else
my_counter <= my_counter + 1;
// Signals and registers declared for VJI instance
wire tck, tdi;
reg tdo;
wire cdr, eldr, e2dr, pdr, sdr, udr, uir, cir;
wire ir_in;
// Instantiation of VJI
my_vji VJI_INST(
.tdo (tdo),
.tck (tck),
.tdi (tdi),
.tms(),
.ir_in(ir_in),
.ir_out(),
.virtual_state_cdr (cdr),
.virtual_state_e1dr(e1dr),
.virtual_state_e2dr(e2dr),
.virtual_state_pdr (pdr),
.virtual_state_sdr (sdr),
.virtual_state_udr (udr),
.virtual_state_uir (uir),
.virtual_state_cir (cir)
// Declaration of data register
reg tmp_reg;
// Deocde Logic Block
// Making some decode logic from ir_in output port of VJI
wire load = ir_in && ~ir_in;
// Bypass used to maintain the scan chain continuity for
// tdi and tdo ports
bypass_reg <= tdi;
// Data Register Block
always @ (posedge tck)
if ( load && sdr )
tmp_reg <= {tdi, tmp_reg};
// tdo Logic Block
always @ (tmp_reg or bypass_reg)
if(load)
tdo <= tmp_reg
else
tdo <= bypass_reg;
endmodule
