11 years agoVHDL2008 matching equality operator
i can't get VHDL-2008 matching equality operator compiled on quartus2.
when i compile the code below it says: Error (10327): VHDL error at test.vhd(13): can't determine definition of operator ""?="" -- found 0 possible definitions 'VHDL 2008' option is being chosen on Assignments > Settings > Complier Settings > VHDL input setting . wondering what i have done wrong. any suggestions? thanks. code:library ieee; use ieee.std_logic_1164.all; entity test is port( a,b: in std_logic_vector(3 downto 0); y: out std_logic_vector ); end test; architecture rtl of test is begin y <= a ?= b; end rtl;
quartus2 version : Quartus II 64-Bit Version 15.0.0 Build 145 04/22/2015 SJ Web Edition
My understanding is that the type ?= returns is the smallest element from the comparation. so in this case std_logic. You try to assign this to a vector. I could be wrong, but does changing the type of y work?
[edit]Reread the specs, it returns ulogic[/edit] - Altera_Forum
y need to be a std_logic, not a std_logic_vector.
?= returns a single bit. If it has to be a vector, maybe try: y(0) <= a ?= b; - Altera_Forum
Thanks for the replies!
Actually what I did at the first place was declaring y as std_logic, but seems it somehow got messed up when I copied the code to the thread. (' ' appeared as burried backspaces in the source file? I don't know). I also had tried std_ulogic(_vector) but no difference. I tried the following code just in case but again got the same error message for both y and z(0). library ieee; use ieee.std_logic_1164.all; entity meqtest is port( a,b: in std_logic_vector(2 downto 0); y: out std_logic; z: out std_logic_vector(1 downto 0) ); end meqtest; architecture rtl of meqtest is begin y <= a ?= b; z(0) <= a ?= b; end rtl; Thanks again, - Altera_Forum
It could be the fact that Quartus VHDL 2008 support is far from complete. The matching equality operator is also implicitly used when you use the following code:
They may mean they only support this form. Otherwise, raise a support ticket for better 2008 support? Does the code compile fine in Modelsim?a : std_logic; .... if a then - Altera_Forum
Hi Tricky,
Tried Modelsim (starter 10.3d) and it turned out it's not happy with the code as well, saying : Signal "a" is type ieee.std_logic_1164.STD_LOGIC_VECTOR; expecting type ieee.std_logic_1164.STD_LOGIC. I double checked the the env variable VHDL93 has been chanted to 2008 in modelsim.ini file. It looks pretty much like what you've said. I'll raise a flag to Altera. Thanks for your help. - Altera_Forum
I just compiled your code in Modelsim, and it works just fine. The errors you get pop out if you are compiling in 93 mode.
You can compile each file with a specified VHDL version: vcom meqtest.vhd -2008 And it compiles just fine. - Altera_Forum
Just tried as you indicated in Modelsim and got it working. Thanks a lot!
also sent a feedback to altera. hope it's supported in Q2.
