11 years agoVHDL2008 matching equality operator
i can't get VHDL-2008 matching equality operator compiled on quartus2. when i compile the code below it says: Error (10327): VHDL error at test.vhd(13): can't determine definition of operator "...
11 years agoHi Tricky,
Tried Modelsim (starter 10.3d) and it turned out it's not happy with the code as well, saying : Signal "a" is type ieee.std_logic_1164.STD_LOGIC_VECTOR; expecting type ieee.std_logic_1164.STD_LOGIC. I double checked the the env variable VHDL93 has been chanted to 2008 in modelsim.ini file. It looks pretty much like what you've said. I'll raise a flag to Altera. Thanks for your help.
