11 years agoVHDL2008 matching equality operator
i can't get VHDL-2008 matching equality operator compiled on quartus2. when i compile the code below it says: Error (10327): VHDL error at test.vhd(13): can't determine definition of operator "...
11 years agoThanks for the replies!
Actually what I did at the first place was declaring y as std_logic, but seems it somehow got messed up when I copied the code to the thread. (' ' appeared as burried backspaces in the source file? I don't know). I also had tried std_ulogic(_vector) but no difference. I tried the following code just in case but again got the same error message for both y and z(0). library ieee; use ieee.std_logic_1164.all; entity meqtest is port( a,b: in std_logic_vector(2 downto 0); y: out std_logic; z: out std_logic_vector(1 downto 0) ); end meqtest; architecture rtl of meqtest is begin y <= a ?= b; z(0) <= a ?= b; end rtl; Thanks again,
