11 years agoVHDL2008 matching equality operator
i can't get VHDL-2008 matching equality operator compiled on quartus2. when i compile the code below it says: Error (10327): VHDL error at test.vhd(13): can't determine definition of operator "...
11 years agoMy understanding is that the type ?= returns is the smallest element from the comparation. so in this case std_logic. You try to assign this to a vector. I could be wrong, but does changing the type of y work?
[edit]Reread the specs, it returns ulogic[/edit]
