(VHDL) I'm Receiving an Error When Trying to Access an Array
Hello All,
I'm trying to output data inside an array to the 7-segment display on my DE1-SoC board.
Here are my variables:
display : out std_logic_vector (6 downto 0);
type bigDisplay is array (0 to 4, 0 to 6) of bit;
signal displayArray : bigDisplay;
Here is the code:
display <= displayArray (0, 6-0);
This is the error I receive:
Error (10381): VHDL Type Mismatch error at Final_Project.vhd(326): indexed name returns a value whose type does not match "std_logic_vector", the type of the target expression
So, I'm guessing I need to convert my bit array to output to the std_logic_vector? How should I do this?
You can use the following to convert bit_vectors/ bit to std_logic_vector:
Use IEEE.STD_LOGIC_1164 package's function To_StdLogicVector
FUNCTION To_StdLogicVector ( b : BIT_VECTOR ) RETURN std_logic_vector;
- Pvand1
Alternatevely you might use:
Type sevseg_t is std_logic_vector(6 downto 0); signal sevseg is array(0 to 4) of sevseg_t;And then you can directly use the returned value of the array.
Also try using std_logic instead of bit asit helps to spot potential problems when simulating your design.
- Abe
