LRect
7 years ago(VHDL) I'm Receiving an Error When Trying to Access an Array
Hello All, I'm trying to output data inside an array to the 7-segment display on my DE1-SoC board. Here are my variables: display : out std_logic_vector (6 downto 0); type bigDisplay is array (0 ...
- 7 years ago
You can use the following to convert bit_vectors/ bit to std_logic_vector:
Use IEEE.STD_LOGIC_1164 package's function To_StdLogicVector
FUNCTION To_StdLogicVector ( b : BIT_VECTOR ) RETURN std_logic_vector;
Pvand1
7 years agoAlternatevely you might use:
Type sevseg_t is std_logic_vector(6 downto 0);
signal sevseg is array(0 to 4) of sevseg_t; And then you can directly use the returned value of the array.
Also try using std_logic instead of bit asit helps to spot potential problems when simulating your design.
