11 years agoVHDL coding issue about AND gate
Hi Dears,
It's very simple to draw single bit AND multi-bit bus in schematic design. i.e: http://www.alteraforum.com/forum/attachment.php?attachmentid=10961&stc=1 However, I have to design analogous fucntion by using an urgly way. i.e:PreMHQ1P <= PosMHQAD and (AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb); Is there other simpler way to code above function (such as "PreMHQ1P <= PosMHQAD and AddAndDb;") in VHDL? PS: AddAndDb is single bit signal, and PreMHQ1P and PosMHQAD are multi-bits bus (the bus width is 21-bit).6 Replies
I suggest using if:
if singlebit = '1' then out <= bus; else out < = (others => '0'); end if; - Altera_Forum
Assuming you are using std_logic and std_logic_vector:
Write a function:
Put the function in a package and you can re-use it everywhere.function copyextend( l : std_logic; width : positive) return std_logic_vector is variable r : std_logic_vector( width - 1 downto 0); begin for i in 0 to width-1 loop r(i) := l; end loop; return r; end function ; PreMHQ1P <= PosMHQAD and copyextend( AddAndDb, 21 ) ; - Altera_Forum
--- Quote Start --- Assuming you are using std_logic and std_logic_vector: Write a function:
Put the function in a package and you can re-use it everywhere. --- Quote End --- Hi josyb, Thanks for you reply! The "r(i):=l" should be changed to "r(i):= r(i) and l"?! Am i right?function copyextend( l : std_logic; width : positive) return std_logic_vector is variable r : std_logic_vector( width - 1 downto 0); begin for i in 0 to width-1 loop r(i) := l; end loop; return r; end function ; PreMHQ1P <= PosMHQAD and copyextend( AddAndDb, 21 ) ; - Altera_Forum
--- Quote Start --- I suggest using if: if singlebit = '1' then out <= bus; else out < = (others => '0'); end if; --- Quote End --- Hi kaz, Yes, it's a simple way than mine. Thanks! - Altera_Forum
No this function makes a N-wide std_logic_vector filled with copies of the std_logic input argument 'l'.
If you want a function to do the 'and' operation between a std_logic and a std_logic_vector:
This is effectively overloading the and operator. It may seem the nicest solution, but beware: it will be silently applied even if it may not be your intention. So my first solution, copyextend, is clearer as it unequivocally shows the intent of the operation. As a rule: it is not a good idea to overload operators for standard types.function "and"( v: std_logic_vector; l : std_logic; width : positive) return std_logic_vector is variable r : std_logic_vector( width - 1 downto 0); begin for i in 0 to width-1 loop r(i) := v(i) and ll; end loop; return r; end function ; PreMHQ1P <= PosMHQAD and AddAndDb ; - Altera_Forum
--- Quote Start --- No this function makes a N-wide std_logic_vector filled with copies of the std_logic input argument 'l'. If you want a function to do the 'and' operation between a std_logic and a std_logic_vector:
This is effectively overloading the and operator. It may seem the nicest solution, but beware: it will be silently applied even if it may not be your intention. So my first solution, copyextend, is clearer as it unequivocally shows the intent of the operation. As a rule: it is not a good idea to overload operators for standard types. --- Quote End --- Hi josyb, I got it. I'm so sorry that i didn't read your first post carefully. Now, i'm clear. Thank you again for you help.function "and"( v: std_logic_vector; l : std_logic; width : positive) return std_logic_vector is variable r : std_logic_vector( width - 1 downto 0); begin for i in 0 to width-1 loop r(i) := v(i) and ll; end loop; return r; end function ; PreMHQ1P <= PosMHQAD and AddAndDb ;
