11 years agoVHDL coding issue about AND gate
Hi Dears, It's very simple to draw single bit AND multi-bit bus in schematic design. i.e: http://www.alteraforum.com/forum/attachment.php?attachmentid=10961&stc=1 However, I have to...
11 years ago --- Quote Start --- No this function makes a N-wide std_logic_vector filled with copies of the std_logic input argument 'l'. If you want a function to do the 'and' operation between a std_logic and a std_logic_vector:
function "and"( v: std_logic_vector; l : std_logic; width : positive) return std_logic_vector is
variable r : std_logic_vector( width - 1 downto 0);
begin
for i in 0 to width-1 loop
r(i) := v(i) and ll;
end loop;
return r;
end function ;
PreMHQ1P <= PosMHQAD and AddAndDb ; This is effectively overloading the and operator. It may seem the nicest solution, but beware: it will be silently applied even if it may not be your intention. So my first solution, copyextend, is clearer as it unequivocally shows the intent of the operation. As a rule: it is not a good idea to overload operators for standard types. --- Quote End --- Hi josyb, I got it. I'm so sorry that i didn't read your first post carefully. Now, i'm clear. Thank you again for you help.
