11 years agoVHDL coding issue about AND gate
Hi Dears, It's very simple to draw single bit AND multi-bit bus in schematic design. i.e: http://www.alteraforum.com/forum/attachment.php?attachmentid=10961&stc=1 However, I have to...
11 years ago --- Quote Start --- Assuming you are using std_logic and std_logic_vector: Write a function:
function copyextend( l : std_logic; width : positive) return std_logic_vector is
variable r : std_logic_vector( width - 1 downto 0);
begin
for i in 0 to width-1 loop
r(i) := l;
end loop;
return r;
end function ;
PreMHQ1P <= PosMHQAD and copyextend( AddAndDb, 21 ) ;
Put the function in a package and you can re-use it everywhere. --- Quote End --- Hi josyb, Thanks for you reply! The "r(i):=l" should be changed to "r(i):= r(i) and l"?! Am i right?
