18 years ago
VHDL code
Hello Guys
I got this Code
library ieee;
use ieee.std_logic_1164.all;
entity NewLUT is
port
clk : in std_logic;
--encoder_a : in std_logic;
data_in : in integer range 3185 to 4215 ; --std_logic_vector(12 downto 0);
data_out : out std_logic_vector (30 downto 0);
out_ready : out std_logic
end;
architecture arc_NewLUT of NewLUT is
signal temp : std_logic;
begin
process
begin
if CLK'EVENT and CLK = '1' then
temp <= '1';
if temp = '1' then
case data_in is
when 3185=> data_out <= ("1010101101110111011101110111100");
when 3186=> data_out <= ("1010101101101001110100000011011");
when 3187=> data_out <= ("1010101101011100001010001111011");
when 3188=> data_out <= ("1010101101001110100000011011010");
when 3189=> data_out <= ("1010101101000000110110100111010");
when 3190=> data_out <= ("1010101100110011001100110011001");
when 3191=> data_out <= ("1010101100100101100010111111001");
when 3192=> data_out <= ("1010101100010111111001001011001");
when 3193=> data_out <= ("1010101100001010001111010111000");
when 3194=> data_out <= ("1010101011111100100101100011000");
when 3195=> data_out <= ("1010101011101110111011101110111");
when 3196=> data_out <= ("1010101011100001010001111010111");
when 3197=> data_out <= ("1010101011010011101000000110110");
when 3198=> data_out <= ("1010101011000101111110010010110");
when 3199=> data_out <= ("1010101010111000010100011110110");
when 3200=> data_out <= ("1010101010101010101010101010101");
when 3201=> data_out <= ("1010101010011101000000110110101");
when 3202=> data_out <= ("1010101010001111010111000010100");
when 3203=> data_out <= ("1010101010000001101101001110100");
when 3204=> data_out <= ("1010101001110100000011011010011");
when 3205=> data_out <= ("1010101001100110011001100110011");
when 3206=> data_out <= ("1010101001011000101111110010011");
when 3207=> data_out <= ("1010101001001011000101111110010");
when 3208=> data_out <= ("1010101000111101011100001010010");
when 3209=> data_out <= ("1010101000101111110010010110001");
when 3210=> data_out <= ("1010101000100010001000100010001");
when 3211=> data_out <= ("1010101000010100011110101110000");
when 3212=> data_out <= ("1010101000000110110100111010000");
when 3213=> data_out <= ("1010100111111001001011000110000");
when 3214=> data_out <= ("1010100111101011100001010001111");
when 3215=> data_out <= ("1010100111011101110111011101111");
when others => data_out <= ("1111111111111111111111111111111");
end case;
else
data_out <= ("0000000000000000000000000000000");
end if;
out_ready <= '1';
wait for 25 ns; -- ERROR
out_ready <= '0';
end if;
-- Add a flag to be used as a clk to the register
end process;
end arc_NewLUT ;
the error msg is : error (10533): vhdl wait statement error at newlut.vhd(75): wait statement must contain condition clause with until keyword.
Why is this error i did not want UNTIL all i need to wait for 25 ns evrey time the code uses the case statement.
    Amirster, can you take a step back and explain what you're trying to do? In the original code you had a wait of 25ns. Synthesizable VHDL doesn't have a strong concept of time. The suggestions of making a counter depend on your clock frequency, which is outside of the VHDL construct. For example, if you made a counter that waits for 5 cycles, that will be different if you feed a 10MHz clock into the system versus a 100MHz clock.
    If you're looking for pure delay(and no registers), that is strongly recommended agains. There are cases where people do it, but it requires min/max setup and hold timing analysis, and can be quite complicated. I think we can answer your question better if you describe your problem from a higher level, as you most likely don't want a pure delay.
    The first step is to have some kind of clock, a couple of time higher then the requested time intervals. What I usually do is make the design synchroneous to a masterclock.
    You can evaluate "on rising edge".
    I am used to the old AHDL language of Altera ( early user, late adapter....) it will look like:
    DFF.clk := Global clock ; evaluate every clock pulse
    DFF.d := Data == Value ; Latch result
    Result := DFF.q ;
    DFF2.clk := Global clock ;
    DFF2.d := Result ;
    Result2 := DFF2.q ; Delaye with one clock pulse
    eg in hardware you are creating a delay pipeline.
    Other solutions are start a counter and gate the result at a certain clock count,
    Use shift registers ( which are in fact cascaded DFF's )
    While writing VDL, just think in hardware!
    Succes,
    Andries
