The first step is to have some kind of clock, a couple of time higher then the requested time intervals. What I usually do is make the design synchroneous to a masterclock.
You can evaluate "on rising edge".
I am used to the old AHDL language of Altera ( early user, late adapter....) it will look like:
DFF.clk := Global clock ; evaluate every clock pulse
DFF.d := Data == Value ; Latch result
Result := DFF.q ;
DFF2.clk := Global clock ;
DFF2.d := Result ;
Result2 := DFF2.q ; Delaye with one clock pulse
eg in hardware you are creating a delay pipeline.
Other solutions are start a counter and gate the result at a certain clock count,
Use shift registers ( which are in fact cascaded DFF's )
While writing VDL, just think in hardware!
Succes,
Andries
