13 years agovhdl code for state machine
Hai,
Can anyone justify what the different between two line codes below: 1) case cycle is when 0l1l7 =>cp<=SXT(bm,11)+b3; end case 2) if cycle=2 or cycle=3 then cm<=SXT(b2,11)-b3; end if I'm curious the function of "l". Is it it mean by "AND" function? Thanks in advance3 Replies
| in this context is just to combine several cases in one line and avoid repeating some code.
is equivalent towhen 0|1|7 =>cp<=SXT(bm,11)+b3;when 0 => cp<=SXT(bm,11)+b3; when 1 => cp<=SXT(bm,11)+b3; when 7 => cp<=SXT(bm,11)+b3; - Altera_Forum
IIRC, | can only be used in case statements or in with..select statements. It is not an "or" operator.
Hai Daixiwen and Tricky,
Thanks for your explanations. I understand now, very appreciates. :)
