15 years ago
Verilog simulation
I wonder if what I've in mind is possible.
Imagine I've a 64bit counter that rolls to 0 when the count is 64'hFFFFFFFFFFFFFF0. The counter is described in Verilog code.
The counter has no signal to load a particular counter value.
I want to simulate counter behaviour and test if it resets when expected.
I don't want to simulate 2^64 clock cycles foroabvious reasons.
Is there a way to write a tesbench that, at a certain simulation point,
sets a particular value in the register of the counter?
My question is then:
is it possible, in simulation, to set a particular state in the circuit under test?
As example, is it possible to put a finite state machine in a not defined state, to check it's behaviour?
Thx for your help.
P.S. Is this the correct forum for Verilog questions?
Do you know a more adequate one?
    you can take a look at the ModelSim force command, or right click the signal in the Objects window to look for the Force window
    I solved the problem using Verilog.
    The command that should be used is 'force' followed by 'release'.
    Here's a snmipset of the code:
    initial
    begin
    reset=1;{read_write, ready, write_OK}=3'b000;# period;
    reset=0;{read_write, ready, write_OK}=3'b000;# (2*period);
    {read_write, ready, write_OK}=3'b010;# period;
    {read_write, ready, write_OK}=3'b001;# period;
    // ac_state is the name of the internal node
    force UUT.ac_state = 5'b00000;# period;
    release UUT.ac_state;# (3*period)
    $stop;
    end
    endmodule
