VerilogStudent's avatar
VerilogStudent
6 years ago
Verilog - Mealy To Moore And State Diagram
Hey, i got a question and i want to know if i did right.
This is the Verilog code and i need to show the state diagram. this is what i did.
THE CODE
And this is the state. I think.
and the next question is, how can i convert this code from Mealy to Moore?
a clue please. a reference to youtube video or article. TY.
EDIT
This is the Moore code
can someone tall me if this is correct?
  • Ok i see. And i`m doing this because this is the work we asked to do.
    So i added the Moore Diagram, is this ok? and now i can convert it?
  • sstrell's avatar
    sstrell
    Looking at your Moore code, you shouldn't have two matching entries in a case statement, which Verilog might let you get away with, but you shouldn't do it.
    But the design is inherently a Mealy state machine (dependent on the state and x), so I'm not sure why you want/need to turn it into a Moore machine.
    #iwork4intel
    • VerilogStudent's avatar
      VerilogStudent
      What do you mean by "two matching entries"? you mean when i write
      begin y = 0
      and then y=1 for example? if does, how can i fix it?
      • sstrell's avatar
        sstrell
        No, I mean you shouldn't have two identical entries in a case statement (two s1, two s2, two s3).
        But as I said, there's no good way to fix this because the basic design is inherently a Mealy machine. What is your goal here and why do you want to change it into a Moore machine?
        #iwork4intel
