11 years ago
veilog code for demux unwanted latch at demux output problem
hey guys!! here is my code for 1:16 demux in verilog (quartus 2)
module demux(sel, din , dout0 , dout1 ,dout2 , dout3 , dout4 , dout5 ,dout6 ,dout7 ,
                 dout8 ,dout9 , dout10 , dout1 , dout12 , dout13 , dout14 , dout15);
input  din;
input sel;
output dout0 ,dout1 ,dout2 ,dout3 ,dout4 ,dout5 ,dout6 ,dout7,
         dout8, dout9, dout10, dout11 ,dout12 ,dout13 , dout14 ,dout15;
reg    dout0 ,dout1,dout2 ,dout3 ,dout4 ,dout5 ,dout6 ,dout7,
         dout8 ,dout9 ,dout10 ,dout11 ,dout12 ,dout13 ,dout14 ,dout15 ;
always @(sel or din) begin
 case(sel)
     4'b0000: dout0 = din ;
      4'b0001: dout1 = din ;
      4'b0010: dout2 = din ;
      4'b0011: dout3 = din ;
      4'b0100: dout4 = din ;
      4'b0101: dout5 = din ;
      4'b0110: dout6 = din ;
      4'b0111: dout7 = din ;
      4'b1000: dout8 = din ;
      4'b1001: dout9 = din ;
      4'b1010: dout10 = din ;
      4'b1011: dout11 = din ;
      4'b1100: dout12 = din ;
      4'b1101: dout13 = din;
      4'b1110: dout14 = din;
      4'b1111: dout15 = din;
      endcase
end
endmodule
after compilation i get this warning :
[h=3]verilog hdl always construct warning at <location>: inferring latch(es) for variable "<name>", which holds its previous value in one or more paths through the always construct[/h]
how can i write this code without getting this warning because i do not want any latches there...
any help is welcome.
    To prevent latches in combinatorial logic, you need to make sure that every bit of every variable has an assignment in every branch of the procedural code of your always block. You can do that by assigning a default value to every doutN bit before the case statement.
     dout0 = 1'bx; dout1 = 1'bx; ...
     case(sel)
    However a better way write this code is to index into a bit vector
    module demux( // use Verilog-2001 syntax for your ports so you only have to declare these once, not up to 3 times
      input wire  din,
      input sel,
      output wire dout0 ,dout1 ,dout2 ,dout3 ,dout4 ,dout5 ,dout6 ,dout7,
    reg  douts;
    assign {dout0 ,dout1 ,dout2 ,dout3 ,dout4 ,dout5 ,dout6 ,dout7,
             dout8, dout9, dout10, dout11 ,dout12 ,dout13 , dout14 ,dout15} = douts;
                 douts = 16'bx;
                 douts = din;
        end
    endmodule
    You are assign 16 different output latches.
    Each output holds it's previous value.
    If you don't want clock, make it an always @(posedge clk) block. Then the latches will be registers.
    Pete
