11 years agoTo prevent latches in combinatorial logic, you need to make sure that every bit of every variable has an assignment in every branch of the procedural code of your always block. You can do that by assigning a default value to every doutN bit before the case statement.
always @(sel or din) begin
dout0 = 1'bx; dout1 = 1'bx; ...
case(sel)
4'b0000: dout0 = din ;
4'b0001: dout1 = din ; However a better way write this code is to index into a bit vector module demux( // use Verilog-2001 syntax for your ports so you only have to declare these once, not up to 3 times
input wire din,
input sel,
output wire dout0 ,dout1 ,dout2 ,dout3 ,dout4 ,dout5 ,dout6 ,dout7,
dout8, dout9, dout10, dout11 ,dout12 ,dout13 , dout14 ,dout15
reg douts;
assign {dout0 ,dout1 ,dout2 ,dout3 ,dout4 ,dout5 ,dout6 ,dout7,
dout8, dout9, dout10, dout11 ,dout12 ,dout13 , dout14 ,dout15} = douts;
douts = 16'bx;
douts = din;
end
endmodule
